Need Help!!2002 acura Tl-s vsa and exclamation mark is on
can anyone help me?...my exclamation light stay on and after driving for a few minutes my vsa light turn on too, but when I restart the car the vsa turn off and my exclamation mark light stay on solid ..vsa light turn on again when i drive..I checked the tire pressure and car fluids and its not low.my car is about 200k... I had my buddy checked the car with a code scanner and there was no code..check engine light is not on..my buddy said these kind of car has tranny problems but since there was no code...the tranny is fine that what he said....tranny shift fine and there is no noises...
Welcome Bobby2013 !!!
Chances are that it's a sensor on the edge.
No codes or going into fail-mode is good. Have ya done any recent brake work ?
If it's a component shared by the ABS and VSA, like a wheel sensor, then any newer OBD II/ABS diagnostic tool can read the code and provide some guidance on what is causing the indicator to light. If it is VSA specific, like a yaw angle sensor, then you'll need a Honda/Acura diagnostic tool to read the code(s).
mada51589
05-03-2022 08:54 PM
