Need help with 2000 TL tranny asap!
I have a 2000 Acura TL that has 138xxx miles on it. The transmission just started to act funny. When I first drive the car it drives fine. After a couple minutes of driving it would act up. When it is shifting into 3rd it will take a couple seconds to get into gear. Also after a while of driving the tranny doesn't want to work. I would turn off the car for a minute or so and it would work again. If anyone has any info that would help let me know.
With any luck you won't get one of the lexus models with terminal engine sludging, cadillacs with head bolt threads stripping in the block, or nissans with piston ring failure among others. I understand your frustration, but in the last couple years a lot of companies have gotten stingy with their warranties. "Lifetime" warranties on auto parts are pretty much a joke as they now enforce the fine print. I attribute it to the sluggish economy most of us are dealing with.
Pham Alvan
May 18, 2021 06:48 AM
Pham Alvan
Mar 16, 2016 09:17 AM
... you're probably f'd man. no such thing as little problem with our shitty ass transmissions, unless you call a $3200+ fix a "little problem"
