Need Advice -- Code P1457 - DIY ?
Old Oct 6, 2008 | 04:12 PM
smartypants's Avatar
Hi All :
I had the check engine light code decrypted to a P1457 which is apparently a evap leak condition. They further diaged it to "needs a EVAP Canister and Vent Shut Valve."
Is this the typical fix ? Can a DIY'er do this work or is it stealership territory ?
smartypants
Old Oct 6, 2008 | 05:09 PM
TLer trash's Avatar
Originally Posted by smartypants
Hi All :
smartypants
The vent shut valve is probably THE most common cause for that code. It's located on the canister in front of the fuel tank. Try the valve first. If it's full of charcoal pieces, you need the canister too. Beyond that, I'd recommend the dealer. Evap codes can drive you nuts. Honda/acuras seem especially good at testing fine when they are bad or intermittent. Some dealer techs will tell you to "assume bad unless proven otherwise" on some of the solenoid valves.
Old Oct 6, 2008 | 07:47 PM
fsttyms1's Avatar
that and double check your gas cap is on tight. (more than 3 clicks)
Mike734
Dec 10, 2021 01:25 PM
tsx_boy
Dec 13, 2019 08:33 PM
soupi
14
Nov 15, 2015 11:15 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
