Motor mount torque specs? 99 TL HELP!
Old Aug 24, 2010 | 04:48 PM
  #41
gold2003tl (90)'s Avatar
2003 TL-p
Originally Posted by hrod26
Gold2003tl...just curious but you changed the rear mount and got rid of your thud/vibration? I just replaced my front and side but I still have shudder at idle in drive/reverse
the thud i had was the engine slamming back and forth when changing gears. replace the rear mount if you suspect its bad.
Old Sep 28, 2010 | 09:29 AM
  #42
webmastir's Avatar
2003 TL
Originally Posted by dudeinaTL
Fluid sound is normal. When I took my old front mount out, I could hear fluid but it was also leaking, as well as loose as hell. I put the same Duralast mount in - they have a lifetime warranty.
lifetime warranty? you sure about that?
(going to order my front & side mounts tomorrow)
trying to decide which vendor to go with.
also, is it best to contact them directly via email & tell em you're with acurazine to get a discounted pricing?
Old Sep 28, 2010 | 10:33 AM
  #43
dudeinaTL's Avatar
Yup, Limited Lifetime warranty at AutoZone.
Funny you replied when you did...looks like I'll be utilizing that lifetime warranty this weekend....front mount is shot...got like 2-3 inches of movement....will see if I can shoot a video.
Old Sep 29, 2010 | 09:14 PM
  #44
dudeinaTL's Avatar
Someone tell me if this looks bad...
http://www.youtube.com/watch?v=G3xvZYkW5fc
Old Oct 11, 2010 | 05:49 AM
  #45
Luke7's Avatar
WNC Real Estate Sales99TL
HMMM Doesn't look bad. Mine moved very quickly and it was more evident that it was loose and shot.
Old Oct 13, 2010 | 06:46 PM
  #46
BARRACUDAMOTORS's Avatar
How many mounts is on tl-s and what you guys pay for at autozone. thanks
Old Oct 13, 2010 | 07:10 PM
  #47
webmastir's Avatar
2003 TL
there are 3 (front, side, rear) engine mounts (& if iirc, 2 tranny mounts too?)
i wouldn't buy them from autozone. i'd get 'em through an acurazine sponsor. that way you could get a discount through them instead. makes sense if you're into saving some $$
Old Oct 13, 2010 | 07:16 PM
  #48
Is that oem parts, becouse everybody says that oems are bad
Old Oct 13, 2010 | 08:37 PM
  #49
2003 TL-p
^ yeah oem parts are ass, but the after market stuff you find at advanced auto or autozone are just oem replacements (same stuff pretty much). they are still ass, its just they might come with a warranty or be cheaper.
spend some time and poly fill the mounts, which is my next project.
Old Oct 13, 2010 | 08:59 PM
  #50
2003 TL-p
arghhh!, i just hate seeing our shitty motor mounts in action, makes me want to thats just how they are.
if you add ingalls stiffy engine tq damper, its basically keeps the engine in place and minimizes moment, take it, it still moves. im going to change my damper setting to a stiffer setting since there is still some moment id like to get rid of.
over time the rubber in the mount gets worked up so much it looses its elasticity and allows more moment,eventually it breaks.
Old Oct 14, 2010 | 07:29 PM
  #51
What you guys think abouth parts from ebay are they any good?
http://cgi.ebay.com/ebaymotors/99-03...item5195af8728
I think price is OK plus lifetime warranty
Old Dec 23, 2010 | 05:01 PM
  #52
Tyman's Avatar
Motor Mounts
Aloha,
I am in the middle of replacing my front mount (the one pointing to the front of the car) and I have everything off expect for the last bolt on the alum bracket on the motor. Its the one behind the exhaust down pipe. How the hell did you guys break this loose? I have a 14mm wench and 10" of pipe for leverage and I can not break it lose. Also, I am doing this on a garage floor with no lift other then a floor jack. Do you use special tools or do I just need to drink more muscle milk?
Mahalo
Old Dec 23, 2010 | 10:30 PM
  #53
Tyman's Avatar
Never mind guys, I figured out what I was doing wrong. Things work allot better when you loosen something instead of tightening it. lol Thanks again for all the tips and hints in this page, I was able to replace both my mounts in about 8 hrs.
Old Apr 26, 2011 | 01:28 PM
  #54
webmastir's Avatar
2003 TL
so i never ordered these a while back, but i am right now(finally)
didn't we get a discount via coupon code or somin through http://acuraautomotiveparts.org ?
cause front + side = $200 & with shipping/tax it's another $20 ....so $220
can't remember how we were supposed to get a discount on these (email em or what it was?)
Old Nov 11, 2012 | 05:52 PM
  #55
yakov1990's Avatar
Hey guys, when changing the rear mount on a 99 TL, is it best to take it out through the top or bottom? How long does it take. I got side and front changed, i dont want my rear to tear my 2 new ones. Thanks
Old Nov 11, 2012 | 05:59 PM
  #56
MilwaukeeDave's Avatar
Take it out through the top. How long depends on you.
Old Nov 11, 2012 | 06:04 PM
  #57
yakov1990's Avatar
unplug all of the hoses?
Old Nov 11, 2012 | 09:18 PM
  #58
victus1's Avatar
The only hose you will unplug is the vac hose to the mount. Here is a diy:
https://acurazine.com/forums/showthr...r+engine+mount
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
wilztlxs
Dec 1, 2015 09:16 AM
Sep 17, 2015 08:57 PM
mossman77
1/2G MDX (2001-2013)
18
Sep 16, 2015 12:21 PM
