Motor mouints
Old Aug 25, 2008 | 01:50 PM
law321's Avatar
Motor mouints
Seems as if i need to replace my motor mounts. can any one give me a little info on where to get good prices on parts, install tips, and such. just the 3 mounts, right?
5 50810-S87-A82 RUBBER ASSY., FR
6 50815-S87-A81 RUBBER ASSY., RR. ENGINE MOUNTING (ECM)
7 50820-S87-A81 RUBBER ASSY., ENGINE SIDE MOUNTING
Lawrence
99tl 105k
Old Aug 25, 2008 | 03:54 PM
fsttyms1's Avatar
Get them here.
http://www.acuraautomotiveparts.org/...catdisplay.jsp
As for install the side is easy, the front is moderate, and the rear is hard. You will need a floor jack to support the motor for the front and rear. Only do one at a time. The front remove the mount to the motor to get it out easier. The rear will be hard. You have to work from top and bottom to get it out. Long extensions and swivels will be needed.
Old Aug 26, 2008 | 12:04 AM
xconradx's Avatar
This thread helped me as well, it looks like my FR is leaking... oh well easy fix.
However, it looks like there is a fluid line or sensor going to the bottom of the mount. What is this?
Old Aug 26, 2008 | 10:23 AM
NSXNEXT's Avatar
They are hydraulic mounts. Just pop the rubber tube off the old one and pop it on the new one. Just remember to do it BEFORE you put the mount back on. I did that once.
Old Aug 26, 2008 | 07:27 PM
xconradx's Avatar
Thanks, good info. Maybe I will make a DIY when I do it.
Jamus22
Jun 11, 2023 10:08 AM
08KBP_VA
Oct 22, 2019 01:55 PM
juanrl
Sep 29, 2015 03:25 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
