Motor mouints
Motor mouints
Seems as if i need to replace my motor mounts. can any one give me a little info on where to get good prices on parts, install tips, and such. just the 3 mounts, right?
5 50810-S87-A82 RUBBER ASSY., FR
6 50815-S87-A81 RUBBER ASSY., RR. ENGINE MOUNTING (ECM)
7 50820-S87-A81 RUBBER ASSY., ENGINE SIDE MOUNTING
Lawrence
99tl 105k
Lawrence
99tl 105k
Get them here.
http://www.acuraautomotiveparts.org/...catdisplay.jsp
As for install the side is easy, the front is moderate, and the rear is hard. You will need a floor jack to support the motor for the front and rear. Only do one at a time. The front remove the mount to the motor to get it out easier. The rear will be hard. You have to work from top and bottom to get it out. Long extensions and swivels will be needed.
This thread helped me as well, it looks like my FR is leaking... oh well easy fix.
However, it looks like there is a fluid line or sensor going to the bottom of the mount. What is this?
Received 1,080 Likes
Jamus22
06-11-2023 10:08 AM
xsilverhawkx
09-28-2015 06:51 PM
09-25-2015 06:14 PM
50810, 50810s87a81, 50810s87a82, 50815s87a81, 50815s87a82, 50820s87a81, 50820s87a81acura, a82, engine, fr, honda, motor, mounting, mounts, rrecm, s87
