missfiring
Old Sep 13, 2012 | 01:24 PM
slowrush24's Avatar
missfiring
My car I think is missfiring when I start it and also when I'am driving. The car vibrates or hesitates/ acts like its going to cut out. I changed the spark plugs less than a year ago so I dont think thats the problem.
ANY SUGESTIONS OR IDEAS ??
Old Sep 13, 2012 | 02:28 PM
mugenspire's Avatar
3 pedals in my 99 TL
check your coil packs. you can buy one to test them all out. just pull them out one at a time from each cylinder while the car is running. if the rpm changes when you remove the coil pack then those cylinders are fine, if nothing happens then those ones are bad. it can be one or two its usually one. the cylinders are numbered from 1-2-3 from rear passenger side to driver and 4-5-6 front passenger to driver side. hope that helps.
Old Sep 13, 2012 | 04:29 PM
3.2TLc's Avatar
Did you use the good "oem" NGK plugs or cheapos ? .... How many miles are on the car at the present time ? Is the car's CEL on.....? If so, have the codes checked.
By the way that you described the way that the motor is acting, it appears as though Mugenspire's advice to look for a bad coil pack would be a good place to start. As our cars age with 10 yrs / 100 k on the dial, things start to wear. The coils are about $50 a pop. A very quick and easy check to perform one at a time.
Old Sep 13, 2012 | 04:52 PM
01tl4tl's Avatar
start with a trip to any parts store for a free code scanning/reading
if there are codes for multi cyl misfire you probably need 1 coil
If no codes its not a coil
spark plugs- as said above,,CORRECT NGK 8 dollars each?
if not pull one and inspect--likely problem there as other plugs wont work in the TL
coils can be damaged internally if set down hard on bench during plug change
Guessing you are well past 100kmiles and never cleaned the `egr port and passage of the intake manifold`? that will cause slower start,idle roughness, miss feeling and low power
easy diy 3 cans carb cleaner and a wire coat hanger (no kidding)
Start with a parts store for the FREE code scan (except Ca.)
save time spent guessing
Old Sep 17, 2012 | 01:40 PM
00RubieTL's Avatar
Im having the same issue. I also believe its the ignition coils. Codes read misfiring multiple cylinders. I have NGKs in, did a tune up 4 months ago. The car is currently at a friend's shop, getting fixed. Ill update as soon as the car is fixed.
Old Sep 17, 2012 | 01:45 PM
00RubieTL's Avatar
The car is 12 yrs old
2000 TL (Bought in 99)
104xxx
Oh & my CEL is flashing.
Old Sep 17, 2012 | 03:32 PM
3.2TLc's Avatar
Hey 00RubieTL, Good luck....it's good to have a friend at the shop, otherwise you could get royally hosed, ha...hah ! Multiple misfires are usually just one bad coil, as the codes for the other's just go off due to the erratic running at the time. Ahh...oh...ah !
Old Sep 17, 2012 | 07:48 PM
01tl4tl's Avatar
that is correct,,multi cyl misfire and charging system test good=
buy 1 coil 50 bucks and start testing where it needs to go
we can walk you thru this
you can have a buddy or a mechanic,,but not in the same person
Old Sep 17, 2012 | 07:50 PM
01tl4tl's Avatar
its possible to damage the coil internally during plug change as they are fragile inside
just setting it down on workbench can disrupt it
then a few months later it quits working
Old Sep 19, 2012 | 06:39 AM
3.2TLc's Avatar
Any updates so far, as to progress in resolving the misfiring issues ?
Old Sep 20, 2012 | 10:05 AM
00RubieTL's Avatar
YES Rubie is FIXED!!
Sry I took so long with the update. After 2 days of diagnostics. For $100 ducks (yes i said ducks) & a Monster Seafood Plate from Bob's Fried Clams. He found a bad coil & a leak in the fuel regulator hose. She is running like new once again. Next up timing belt and water pump. Hope this helps yall.
Old Sep 20, 2012 | 01:36 PM
slowrush24's Avatar
guys i checked my spark plugs before buying the coil pack and the damn spark plugs were all lose i guess when i did a tune up i didnt tighten them all the way. car runs better now
Old Sep 20, 2012 | 01:38 PM
slowrush24's Avatar
i think im still going to save up and buy the coil packs though
Old Sep 20, 2012 | 02:51 PM
MilwaukeeDave's Avatar
Only replace coil packs if needed. They either work or don't work no grey area for those. Replacing them and it's not bad is a waste.
Old Sep 21, 2012 | 08:17 AM
00RubieTL's Avatar
I totally agree. "If its not broken, dont fix it."
ksu90
Aug 1, 2015 09:12 PM
briggsypn
2G CL Problems & Fixes
May 31, 2015 02:37 PM
Acadien
Oct 12, 2012 08:38 AM
manteuffel
Mar 12, 2006 11:12 PM
aRIff
Nov 9, 2004 12:12 PM
