Misfire Cyl 3 & Random Misfires
Old Sep 10, 2013 | 07:42 PM
Bearcat94's Avatar
AZ Community Team
2002 TL-S. ~122k miles.
Normal maint, w/Mobil1 (or similar) synthetic. 93 octane gas all the time. Timing belt, plugs, etc., (105k service) completed at ~4/28/08 (66k miles).
Today got stuttering and flashing CEL on start up. Some stuttering after warmed up and no CEL. Later, cold start, got stuttering and CEL at ~45 MPH.
Codes pulled at Autozone:
P0303: Cylinder 3 Misfire
- Vacuum leak
- Ignition System
- Blocked/Faulty Injector
- Engine Mechanical
P1399: Random Cyl Misfires
- Blocked EGR Passage
- Valve clearance
What should I do?
TIA
Old Sep 10, 2013 | 07:46 PM
Bearcat! long time no chat! sad it has to be in this situation, tho.
for the EGR valve, you can unbolt the two bolts that hold it and pick off any carbon that is in there.
This should clear both codes, unless the car has been overheating. has the car been overheating?!
Old Sep 10, 2013 | 07:49 PM
and I didnt know your name was TIA.
Thanks In Advance
Old Sep 10, 2013 | 07:58 PM
Bearcat94's Avatar
AZ Community Team
OK, that's what I was hoping .... EGR Valve. I'll clean it and see how it goes.
Is it OK to drive for a day or so?
(TIA = Thanks In Advance you leg humper.)
Old Sep 10, 2013 | 08:02 PM
as long as the car isnt overheating, I believe its the EGR valve.
it is okay to drive, as long as you dont mind the stuttering due to the EGR valve being blocked by carbon.
and you're slacking. check for white text!
Old Sep 10, 2013 | 08:21 PM
Bearcat94's Avatar
AZ Community Team
Right - it is not overheating.
.... and you're slacking. check for white text!
Old Sep 10, 2013 | 08:59 PM
fsttyms1's Avatar
On the 2nd gen the EGR code is usually caused by the 6 ports that get clogged under teh cover. Id pull the top intake manifold cover off and look for blockages in that and the 6 holes.
As for the misfire, it could be the egr causing a false code, or it could be a coil on #3 going. (very common on these)
Old Sep 10, 2013 | 09:16 PM
Bearcat94's Avatar
AZ Community Team
Will do. If none of that works, I'll try the coil next.
Old Sep 11, 2013 | 07:12 AM
3.2TLc's Avatar
Yeah, if it's been awhile....clean the EGR passageways and TB intake.
Check all the wiring and vac connections.
Old Sep 11, 2013 | 10:12 PM
Bearcat94's Avatar
AZ Community Team
:grrrr:
Cleaned the EGR chases and holes - they were pretty grimy, but not fully blocked.
Could not clean the EGR Valve because I stripped one of the nuts and couldn't get it off.
Seems a little better, but not fixed and still getting hesitation and flashing CEL under throttle at ~45 MPH.
I'm going to check the coils and if OK, take it somewhere to get the EGR valve removed and cleaned.
Old Sep 12, 2013 | 07:53 AM
3.2TLc's Avatar
Hey Bear, remove the coil from the #3 cylinder and see if it makes any difference in the idle rpm.
Pull that plug and see how it appears. Ya may want to buy one new coil and try it on that cylinder. Reset the ECU and see how it runs.
Old Sep 12, 2013 | 03:02 PM
Bearcat94's Avatar
AZ Community Team
Which is number 3??
Old Sep 12, 2013 | 04:47 PM
3.2TLc's Avatar
Hey Bear, the #3 cylinder is located on the far right side of the motor's back side towards the firewall.
Old Sep 13, 2013 | 05:56 PM
Bearcat94's Avatar
AZ Community Team
OK, thanks. Just to make sure I'm looking at the car from the same POV, you mean this one (the red one), right?
I'll probably check them all just in case.
Old Sep 13, 2013 | 07:13 PM
3.2TLc's Avatar
Yeah, that's the #3 cylinder that ya wanna try eliminating as a problem first.
But, with random multiple misfires...it could be just that, a random situation.
Gotta start somewhere !!! Good Luck, man.
Old Sep 13, 2013 | 07:49 PM
firewall
123
456
radiator
this is how i always remember.
Old Sep 14, 2013 | 12:45 PM
fsttyms1's Avatar
That only works if the coilpack is completely dead. You can try that and see what happens. You could also move that coil pack to a different cyl and reset the ecu and when the cel comes back on see if the misfire followed that coil pack.
Old Sep 14, 2013 | 02:54 PM
Nicks2001tl's Avatar
Before the transmission went on my car I had the P0740 code and the p303. Checked all the coils one by one and find out the number 3 was bad.
Replaced it and problem was solved.
Old Sep 15, 2013 | 02:45 PM
Bearcat94's Avatar
AZ Community Team
Did this yesterday. Pulled the plug on each coil pack in turn. All caused a change in idle (tone changed and caused some roughness/hesitation/stuttering.
I've got to get the EGR Valve out and cleaned (or replaced) before anything else.
Looks like I'll need to take somewhere where they can get the nut I stripped off.
Old Sep 15, 2013 | 07:46 PM
3.2TLc's Avatar
Hey Bear, did ya pull the #3 plug and check it ? Did ya swap #3 coil with another after CEL reset ? If everything seems the same, check all the vac hoses and electrical connections. Have ya done any recent work ?
Ya could also try some fuel system cleaner, maybe got some bad gas or an iffy injector. Perhaps try checking the fuel pressure ??? Personally, I don't think that the EGR valve is bad if the passageways were not totally clogged.
Old Sep 20, 2013 | 09:22 AM
Bearcat94's Avatar
AZ Community Team
Had to go out of town for a few days, so dropped it off at the local shop. They did their diagnostic and say that the plugs and coils are good, but compression is inconsistent cyl-to-cyl (140, 120, 130, etc.).
They think the valves need adjusted and that it's related to the CEL/misfires. The car does (and has had for a few months) a pronounced 'tick' when running.
At 122k and .... 10+ years, I don't doubt the valve could use/need adjusting. I just don't know if that would account for misfires and the CEL.
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
joflewbyu2
Oct 8, 2015 11:16 AM
BrownBuck
NY/NJ
Sep 29, 2015 09:53 PM
jmaxima03
Sep 27, 2015 10:22 AM
kencepeda
Sep 26, 2015 05:13 PM
