Midgets In the Dash Board?
Old Mar 5, 2007 | 05:59 PM
lokee99's Avatar
I'm stock and hating it.
Okay so I have a 00 TLP with about 120k. I was letting my lil sis drive so she can learn and when she got in the drivers seat and press the gas I heard this Loud Kocking sounds like some midgets were inside my dash knocking. It dosent last to long about 15 secs. I tried to look under the hood and locate the sound but to no avail I can't find it. I did a search but I didn't find anything that makes me feel like they had the same problem. Help me out PLEASE!
Old Mar 5, 2007 | 06:23 PM
01tl4tl's Avatar
Did someone slip 87 octane in your gas tank?
Or the timing belt tensioner is giving out?
Did you do the timing belt plus tensioner and water pump at 105K?
Old Mar 5, 2007 | 07:13 PM
lokee99's Avatar
No I didnt. Its just a weird sound. The car dosent drive different. Could that be the probelm though?
I did use gas from a racecoast. I used 93 octane though. I need to refill today so im going to shell..
Old Mar 5, 2007 | 07:44 PM
Malayalee King's Avatar
ഥഎണഡഏ Fellas Inc.
midgets in the dash huh...are any of the suspension links or bars loose anywhere? any distortion to the headers or downpipe? i had this prob but it was when i installed after marketheaders and they touched the frame causing it to rumble and sound like midgets in the hood
Old Mar 5, 2007 | 08:40 PM
lokee99's Avatar
Well.. I havent done anything to it. i will check and see if a bar is loose but it seems real loud inside right behind and below the radio. the only thing I had done recently was the Tranny and it was done by acura. So.. I guess I will look tomorrow at the links and bars.
Old Mar 5, 2007 | 09:20 PM
01tl4tl's Avatar
And stop letting sis learn to drive in a TL
Send her to school and abuse their cars instead!
Old Mar 6, 2007 | 02:52 PM
lokee99's Avatar
Okay I looked and nothing. It hasnt made the sound again.
Old Mar 6, 2007 | 02:57 PM
ifrisbee's Avatar
Maybe it was his knees knocking. After all he was letting her learn to drive on his car
Old Mar 6, 2007 | 08:42 PM
Soseductivesf's Avatar
The midgets are on to you! I had some noise coming from the engine and it was my CAI pipe hitting the frame!
Old Mar 8, 2007 | 09:45 AM
dreem1er's Avatar
deal with it
check under the dash or take it apart and see if something can lose......this would explain why you only hear it every once in a while.....
Old Mar 8, 2007 | 10:28 AM
LSBoogie's Avatar
Vaccum up all the crumbs and take out any water/pop containers. With no food around, he will move on....
Old Mar 11, 2007 | 01:35 AM
lokee99's Avatar
Man it's gotta be something deep in there. It's definitely in the dash area. Not in the engine. Dose the vents move in there during th start up of the car. That is usally when I hear it. It just started back so im going nutz here. Someone has to have heard this before. It kinda sounds like a vent or something trying to move and its getting stuck on something so it keeps trying and trying for like 20 secs or so.. HELP ME TOM CRUISE!!! HELP ME OPRAH!!! HELP ME ACURAZINE!!
Old Mar 11, 2007 | 11:43 AM
01tl4tl's Avatar
Try turning the climate control OFF before turning engine off
Its less strain on things when all the eletrics ar off anyway
Start car and listen, then turn climate on and listen again
Old Mar 12, 2007 | 12:10 AM
lokee99's Avatar
Okay today. It did it alot. So when I heard it I started to heater then the noise stopped. So I cut it off then the noise came back. So I kept doing it then it didnt affect it. I really dont wanna go to the dealer and let them rape me. I really dont like'a the rape'a lol. STILL THINKING ON WHAT TO DOOOOOOOOO.
Old Mar 12, 2007 | 12:49 AM
01tl4tl's Avatar
At this point we need to know for certain if the climate doors are vacuum operated
Anyone have the for sure answer on this?
Or get out a vacuum guage and hook it up and have friend cycle the heat controls
Old Mar 12, 2007 | 12:51 AM
01tl4tl's Avatar
And you dont need the dealer for this- just a good Acura guy, look in the phone book under automobile repair for an import shop or Acura specialist
Old Mar 12, 2007 | 03:01 PM
lokee99's Avatar
Well I know recently I noticed that when I try to cut the air flow from the dash to just the floor. It still blows through the dash. Maybe it is that thing that open and closes those whatevas. Maybe someone knows what im talking about.
Old Mar 12, 2007 | 04:31 PM
fsttyms1's Avatar
Im almost 100% positive the climate door is electrical.
Try taking off the glove box. If it is that you will hear it alot easier cause its right there. Does it only do it when the car is running or can you duplicate the sound by shutting it off and turning it to run?
Old Mar 14, 2007 | 10:39 AM
lokee99's Avatar
It only does it when the car is running. I think it is what you said it was. The climate control. I can be driving and when I turn the to the colder setting it will start knocking as if a door is trying to turn. But when I turn it back to hot it will stop. It does this everytime I try to change the temp. It dosent constantly do it. Just for about 20 secs or so.
Old Mar 14, 2007 | 10:41 AM
lokee99's Avatar
Hey fsttyms1 do you think this is a fix that I can do myself? I'm kinda handy lol.
Old Mar 14, 2007 | 02:52 PM
fsttyms1's Avatar
Yes, and if i remember right there is a thread that actually dealt with this not that far back. Try doing a search.
Old Mar 14, 2007 | 03:39 PM
lokee99's Avatar
Originally Posted by mdavisii
I had that EXACT same issue with the noises like "acorns" u r describing. From the passenger side, look behind the carpet (to the left of glove box) and u will see this:
006 79160-S0K-A01 MOTOR ASSY., AIR MIX 1 1999 TL 121.00 96.80
This is an air/mix control (Item #6) that controls your temperature with the climate control. I guarantee you after u replace it, there will be no more issues. Very simple to do, a 15 minute DIY.
I'm almost positive this is what you were talking about fsttyms1. From the thread it sounds like my exact issue. Which index number is it. Or I will just take the part# to Acura and see what they give me and replace that. Thanx anyway.
tsx_boy
Dec 13, 2019 08:33 PM
Jul 16, 2017 07:33 AM
ExcelerateRep
Oct 14, 2015 08:20 AM
2Quik
Sep 23, 2015 01:03 PM
eastcoastguy
Sep 23, 2015 06:29 AM
