Matience Required Light?
Old Jan 6, 2006 | 06:22 PM
Black_Tl_S's Avatar
Resident Ford Tech
When i start my Car, the matience required flashs for like 10 secs....i change my oil every 3k miles with full syn the car has like 74k miles...im a service tech for Ford...so i have no idea what it would. Any help would be appreciated....
Old Jan 6, 2006 | 06:44 PM
derrick's Avatar
Before you turn your ignition from the lock position to the 'standby' (ie electronics lights go on) ... hold BOTH reset and select buttons for 5 seconds ... the maintenance light goes off. It's just a reminder light.
Old Jan 7, 2006 | 04:45 PM
Black_Tl_S's Avatar
Resident Ford Tech
thx man
Old Jan 7, 2006 | 05:18 PM
fsttyms1's Avatar
As for the Maint required light its in your manual on how to reset it.
With the car off,Press and hold the Trip and Reset light with 1 hand, while holding them BOTH in turn your key
to the RUN position (not start but run) and continue to hold them in till they turn off. It takes about 10 seconds.
If you turn the key and then press teh buttons in you will change the Outside Temp settings
In summary its a Dummy light set for every 7500 miles (from time its reset) to inform you its time to change your oil
mada51589
Jan 9, 2025 04:40 PM
Greengecko
Sep 16, 2015 08:19 PM
PortlandRL
Sep 14, 2015 12:01 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
