Marvel mystery oil
Old Oct 21, 2006 | 11:25 AM
Hitlayers's Avatar
Marvel mystery oil
Just wondering since I've used it on an older car and it seemed to work, for the ticking that some of us experience, would Marvel Mystery oil quiet it a little? Or would it be a waste of money and I should just waiting to get the valve ticking noise fixed the right way??
Old Oct 22, 2006 | 09:39 AM
Hitlayers's Avatar
bump
Old Oct 22, 2006 | 06:00 PM
RickRoush03's Avatar
RickRoush03
no, don't bother. bg44k or chevron techron is all you need, the other stuff is nonsense
Old Oct 22, 2006 | 07:04 PM
fsttyms1's Avatar
I Wouldnt use it
Old Oct 22, 2006 | 07:18 PM
Hitlayers's Avatar
OK thankx, so Marvel is out of the question, I'll probably go with BG44K since I've read about it before and with 91,000 miles on my car it should help but as far as the ticking goes, will BG44K silience that in any way or is it more targeted for the fuel injectors??
Old Oct 22, 2006 | 07:59 PM
sbuswell's Avatar
I need 2 more gears
I think gumout regane is just as good if not better than BG44K. I have used both several times now and in my results for my car the gumout seems to work a little better. both work very well though and your car will run smoother than before. I have used techron and thought it was crap, didn't seem to do anything. gumout and BG44K both gave noticeable results. for the money and availability, go with the gumout regane and you'll be happy IMHO.
Old Oct 22, 2006 | 08:25 PM
fsttyms1's Avatar
Are you sure its the valvs ticking. And if you have ticking valves I wouldnt use a bandaid on it. I would have it looked at by a dealer or mechanic
Old Oct 23, 2006 | 07:54 AM
Hitlayers's Avatar
Yeah it's definitely valves, went to the dealer to get something else done and asked if they would check the ticking noise and thats when they told it I need my valves adjusted, they said its nothing major but it will take away the ticking, why does this only happen when the car is warm, not when I first start it up?
IBankMouse
Jun 13, 2020 12:53 PM
Thuneau
Oct 3, 2015 04:19 PM
Skirmich
Oct 1, 2015 12:59 PM
jubikej
1G RDX Problems & Fixes
Sep 30, 2015 01:13 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
