Maintenance required light
Old Aug 22, 2010 | 04:29 PM
Hitlayers's Avatar
What's up everyone, while driving today my "Maintenance required" Light came on, car has 106,000 miles on it, first time ever seeing this, what should I do first?
Old Aug 22, 2010 | 06:09 PM
thewrangler99's Avatar
there's a procedure on the owners mannual to reset it.
Old Aug 22, 2010 | 08:03 PM
01tl4tl's Avatar
you are kidding right hit? you have to know this one!!
oil change reminder light/mait req light
try looking in the diy~
put your left hand thru top of steering wheel- push and hold both trip buttons in
with right hand, turn key to ON - watch as mait light flashes several times then goes out..
you are done
In 6500 miles it will start again as it nears oil change interval schedule- has nothing to do with oil condition- mileage since reset only
Old Aug 22, 2010 | 09:14 PM
fsttyms1's Avatar
Im sorry but i have to say REALLY?????????????????? Your kidding right?????????
This light comes on EVERY 7500 miles.
Taken from the DIY thread
https://acurazine.com/forums/2g-cl-frequently-asked-questions-52/maintenance-required-light-maintenance-schedule-477061/
Old Aug 22, 2010 | 10:41 PM
Mista Juice's Avatar
good lord.....
Old Aug 23, 2010 | 09:17 AM
dudeinaTL's Avatar
Did the TCS and SES lights come on too? Regardless, might be time for a new transmission.
and yes, I'm kidding
Old Aug 23, 2010 | 10:43 AM
Hitlayers's Avatar
Sorry guys, your right, but this shows you how often I drive my cars, I do that amount of mileage in 2 years....so I tend to forget simple things. Thanks guys.
Old Aug 23, 2010 | 11:08 AM
01tl4tl's Avatar
I hope you are changing the oil once a year then--moisture absorbtion in oil from hygroscopic action is bad news on car engines
Make sure you are driving it once a month for 45-60 minutes on the freeway cruising
That will make enough heat in the engine, fluids and exhaust to dry them out,
and charge the battery properly
throw some seafoam or stabil (see- I do like other products!) in the gas to prevent moisture issues and gumming of the fuel- which will make the car run bad when sucked into the fuel system
a few dollars prevention beats a thousand dollar repair
Old Aug 24, 2010 | 10:39 PM
dudeinaTL's Avatar
Well I guess that's more believable...as you would only get the light...every 2 years. Sometimes I can't even remember how old I was 2 years ago.
Old Sep 13, 2010 | 09:16 PM
jayhawk815's Avatar
https://acurazine.com/forums/showthread.php?t=477061
Ok, question here for you guys. I had let it go for awhile, kinda got used to it being on. I've reset the maintenance required light countless times in the past, but now holding the "select" and "reset" buttons with the ignition set to "on" won't reset it. It makes a beeping sound and causes the temperature readout to go cycle from -3 to -3°, beeping at each increment.
Has this ever happened to anyone else? I'm in the process of selling the car and need to get the light reset ASAP.
Old Sep 14, 2010 | 02:51 AM
01tl4tl's Avatar
you got the methods swapped
to rest mait light push and hold the 2 trip buttons
THEN turn key to ON- mait light flashes several times and goes out
DONE
to fix outside temp reading
turn key on- push both buttons--adjust as needed
Old Sep 14, 2010 | 10:15 AM
jayhawk815's Avatar
DONE
Now I feel like a retard. Thanks for the quick resposne, will be sure to take care of it when I get home tonight!
Old Sep 14, 2010 | 04:19 PM
01tl4tl's Avatar
guess how I learned which one goes to temp~
then the method of: put you left hand in--thru the steering wheel to use the buttons
right hand on key in ignition
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
PortlandRL
Sep 14, 2015 12:01 PM
datadr
Sep 12, 2015 09:12 PM
ahsm
Sep 9, 2015 08:35 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
