Maint. Required light stays on
I've got an 01 tl with 96,075 miles and just today when I started up the car the maint. required light stays on. I just changed the oil and i'm not too sure what else it could be.
Its a light that comes on every 7500 miles. All it does is remind you to change your oil. It comes on every 7.5k no matter what. It needs to be reset to turn off and the instructions are in the manual.
press and hold the 2 trip buttons with your left hand while reaching thru the steering wheel- now with your right hand turn key on while holding buttons in- they flash several times and reset-
if you have the key on first, you reset the outside temp guage adjustment
Exquisite One
to calibrate the outside air temp guage!!- there is a 5 degree up or down adjustment range.
Best way to set perfect is place the probe (sits in front of the radiator under hood latch)
in glass of ice cubes with water- should read 32- adjust readout as needed
The purpose of the outside guage- is for when its near freezing temps, and there is moisture on the road or you cross a bridge- if temp is within 5 degres of 32F, ice or black ice on the road is possible
So keeping you aware is its purpose.... as you sit on heated leather and interior auto-temp set at 73, you may forget the dangers outside
Exquisite One
may I suggest a read of the owner manual for a fuller understanding and correct adjustment procedure- its all about the key and the buttons and who what when
here is the free download- or view online- owner handbook- every acura ever made for usa market is there
Click year then model- a pdf file opens- move the little hand over `index` page number- click- opens index- by A B C D--- look up everything you want to know and more!!
https://techinfo.honda.com/rjanisis/...01_OMANUAL.asp
Exquisite One
rockyboy
08-04-2024 10:35 AM
mada51589
05-03-2022 08:54 PM
rockyboy
01-25-2016 06:00 PM
