Low Idle
Old Apr 17, 2020 | 08:27 PM
sexygirl20's Avatar
Low Idle
I have an 02 Acura TL Type S and it seems to have a low idle issue. The car would drive fine but sometimes when coming to a stop for example at a stoplight, the car will seem like it wants to stall. If I mash gas it wouldn't but if I don't it would stall. I service my car like clockwork so I have ruled that out. Spark plugs are still like new. Any thoughts?
Old Apr 17, 2020 | 08:56 PM
Perhaps the MAP sensor, or the manifold absolute pressure sensor.
It sits on top of the throttle body
Old Apr 17, 2020 | 09:57 PM
whitetiger5's Avatar
Have you checked that you can rotate the IACV internal mechanism properly? it requires disassembly which can be tricky but if it were stuck it could be stuck in closed position which kills its ability to bring your idle speed to the correct value.
Old Apr 20, 2020 | 12:15 PM
Acura2g558's Avatar
Does it surge when it's idling or just choke out and try to die? Does it happen when it's a cold start or only when the car is warm?
Old May 24, 2020 | 10:05 PM
sexygirl20's Avatar
Problem Solved
Valve cover gasket is leaking oil. Oil is going into the spark plug. Switched out parts and she's working like a charm.
dylanvans
1G CL Problems & Fixes
Sep 28, 2014 03:39 PM
bored7one4
Nov 8, 2010 09:19 PM
wise2k
Apr 3, 2007 10:44 AM
Dem1K
Nov 1, 2004 10:11 AM
Legend2Die4
Feb 17, 2004 10:29 PM
