loud noise
rear wheel bearing is going
is often the right side but can be either or both
turning changes the load on bearing
diy list https://acurazine.com/forums/2g-tl-1999-2003-98/new-official-2nd-gen-tl-diy-thread-706083/
diy list https://acurazine.com/forums/showthread.php?t=706083
If it were a rear wheel drive car thats always possible
and there is a differential inside the trans,,,
but a rear noise of a high pitch constant sound in motion = rear wheel bearing
iirc its so common the thread title on the diy is: rear wheel bearing diy- because you will need it!
guess how I know what it sounds like,,mine is going out
If you can do rear disc brake jobs and drum brakes- the bearing is a simple punch off once in there.
inside the rear rotors is the park brake system- center hub of rotor is the drum and a mini sized set of shoes are around the axle/bearing on the backing plate
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
