loud noise
Old Nov 9, 2010 | 03:38 PM
racgroup's Avatar
loud noise
i notice a loud noise from the rear as i drive in the highway (like an airplane ) but when turning right the noise stopped....any help
Old Nov 9, 2010 | 04:38 PM
01tl4tl's Avatar
rear wheel bearing is going
is often the right side but can be either or both
turning changes the load on bearing
diy list https://acurazine.com/forums/2g-tl-1999-2003-98/new-official-2nd-gen-tl-diy-thread-706083/
Old Nov 9, 2010 | 05:56 PM
racgroup's Avatar
diy list https://acurazine.com/forums/showthread.php?t=706083
Thanks, I thought so even one mechanic told me it is the differintial????????
Old Nov 9, 2010 | 06:16 PM
01tl4tl's Avatar
If it were a rear wheel drive car thats always possible
and there is a differential inside the trans,,,
but a rear noise of a high pitch constant sound in motion = rear wheel bearing
iirc its so common the thread title on the diy is: rear wheel bearing diy- because you will need it!
guess how I know what it sounds like,,mine is going out
If you can do rear disc brake jobs and drum brakes- the bearing is a simple punch off once in there.
inside the rear rotors is the park brake system- center hub of rotor is the drum and a mini sized set of shoes are around the axle/bearing on the backing plate
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
