Location of ODB II port 2002 Acura TL-S
Old 08-24-2008, 11:45 AM
02CDATLS's Avatar
Where is the connector for the OBD II on a 2002 Acura TL-S.
Any help would be appreciated.
Old 08-24-2008, 01:03 PM
totaledTL's Avatar
Between the seat heater switches, under a little plastic cover.
Old 08-29-2008, 01:11 PM
ഥഎണഡഏ Fellas Inc.
Malayalee King's Avatar
i know thats true on the 99 but on the 2003s (probably the 02s too?) it is right under the dash panel below the steering wheel.
1) put your hand on the ignition.
2) slide it over and put it on the dash piece.
3) slide hand down following the center console dash piece and at the bottom you will feel the odb2 connector. you can also bend down and look at it and dont need to remove a thing.
good luck
Old 08-29-2008, 01:16 PM
rob-2's Avatar
on my 2000 it's between the seat heater switches.
Old 08-29-2008, 01:46 PM
totaledTL's Avatar
Own an '02 TL-S.... it's not under the steering wheel.
Old 08-29-2008, 01:47 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
good luck
That was an 03 only thing. 99-02 were all between the switches.
Old 08-29-2008, 01:54 PM
wham bam thank you ma'am
Rajca's Avatar
my 02 has it between the heat seat switches and my 03 has it just to the right under the steering wheel colum
Old 08-29-2008, 02:03 PM
ഥഎണഡഏ Fellas Inc.
cool -- good info
Zonian22
11-14-2015 01:20 PM
02tljj
09-11-2015 12:37 PM
theinsvnity
09-10-2015 10:22 PM
kuzdu
09-10-2015 08:42 PM
asahrts
09-04-2015 05:55 PM
Quick Reply: Location of ODB II port 2002 Acura TL-S
