LED Resistors
LED Resistors
Im looking for some resistors to eliminate the flickering on the Tl 2001-p for the rear turn signal bulb 7440
But having trouble to find any...
Suggestions? and thanks!
Have you checked the turn signal's relay under the driver's side dash. Sometimes when this goes bad, the lights will appear to flash 'n blink faster than normal.
Are all the turn signal lamps doing this "flickering" ?
If only one check the bulb and connection. If all, replace the flasher relay.
are you running led turn signals or regular bulbs? if your using leds go on ebay and put led resistors they come right up under ten bucks get 4 just in case u do the front turn signals too if not 2 are fine 1 on each turn signal just splice right in to light harness in trunk
Eggs999bacon
09-24-2015 10:08 AM
