leaking tranmission fluid
Old Aug 11, 2009 | 12:41 AM
merkin110's Avatar
I started noticing a leak coming from my tranmission so I had my mechanic inspect it and he replaced the driver side axle seal. After a few days it started leaking again. We then decided to replace the seal again and the axle shaft as well. No luck still leaking. Any suggesions? My transmissions shifts very rough in the morning but smooths out after it goes through a few gears.
Old Aug 11, 2009 | 01:25 PM
Beast2o1's Avatar
4th Gear
i had the same problem with the leaking the seal thats being used is probly to small for thecar i replaced mine 3 times before my transmission guy figured it out!
Old Aug 11, 2009 | 01:40 PM
merkin110's Avatar
I picked up both seals from Acura. So the seals from Acura are too small?
Old Aug 14, 2009 | 03:22 AM
cobalt107's Avatar
Acura dealer replaced mine twice under warranty & still leaks, but not as bad. Oh well!
Mike734
Dec 10, 2021 01:25 PM
spudweb
May 22, 2016 02:39 PM
Avenger411
Oct 11, 2015 03:53 PM
steve
Sep 30, 2015 09:23 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
