Leak from pipe near the top of Pulley
Old Jun 16, 2018 | 01:23 PM
mrxclnc's Avatar
mrxclnc
Exclamation Leak from pipe near the top of Pulley
I have a 2001 Acura TL that has a leak from a pipe near the top-most pulley. I have attached a picture with the area of the leak circled in yellow. Can anyone shed some light on what this hose carries? It is power steering fluid?
Thank You,
Deepak
Old Jun 16, 2018 | 04:22 PM
Iggy's Avatar
High pressure power steering line. If you are sure it's leaking from the crimped area where metal tubing transitions to rubber then the entire line needs to be replaced.
Check to be sure fluid isn't leaking at the pump connection(where the two bolts are), and dripping towards the yellow circled area. There is an O ring at the pump connection that is known to go bad but an easy fix.
Old Jun 19, 2018 | 08:12 AM
Arkady's Avatar
What Iggy said. Check the O-ring, and if it still leaks you need to replace that line. It's not too awful of a job if you've got some mechanical aptitude - the hardest part of it is figuring out how to twist the new line in.
Be glad it's not an Accord! Iggy was having a real fun time replacing the PS pressure line on one of those recently :P
Old Jun 19, 2018 | 10:39 AM
Iggy's Avatar
Wasn't me, I remember the thread though.
Old Jun 19, 2018 | 11:58 AM
Arkady's Avatar
Oh my bad man, it's been a bit since I looked at that thread.
grahats
Aug 4, 2010 10:52 AM
Rajca
Mar 31, 2010 04:17 AM
Rajca
Nov 28, 2009 07:36 PM
peternguyen504
May 9, 2009 10:02 PM
JTso
31
Sep 25, 2007 01:54 PM
