knocking noise
Old Mar 28, 2011 | 09:59 PM
whistlekleen's Avatar
5th Gear
knocking noise
02 tl is making a loud knocking noise. Mainly does it when its in park. Seems to only do it after ive been driving the car for a longer period. The noise comes and goes but when its doing it and its in park it pretty loud. And when I put it in drive the noise seems to speed up with the car than disapear. But than sometimes I think I hear it while in drive and moving, might just be less noisy.
Old Aug 23, 2011 | 10:29 AM
SYNProductionz's Avatar
3rd Gear
I am having the same issue. The knocking noise seems to be really loud when the car is idling. It souns like it is coming from the lifters and also from where one of the belts is spinning. The car drives fine but man do I hate that sound! Did you get your issue resolved? what was the problem?
Old Aug 23, 2011 | 11:18 AM
fsttyms1's Avatar
Have your valves adjusted. Have a mechanic inspect the belt tensioner, they are some times the noise culprit
Old Aug 23, 2011 | 12:30 PM
01tl4tl's Avatar
first suspect is the ac belt tensioner
you can see it at top front of engine,,mine went at 80kmiles,
sounded like a V8 engine.. the bearing was so bad!
get the entire unit for ~100, ck parts store and aftermarket
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
