keyless won't work(new battery)
Old Dec 6, 2006 | 04:01 PM
new 2ng gen tl guy's Avatar
5th Gear
Can't seem to sync my current keyless remote to the car, new battery, remote is supposedly the one that came with the car...any ideas?
Old Dec 6, 2006 | 09:34 PM
fsttyms1's Avatar
changing the battery shouldnt have caused it to not work. Dont know why it its not working??
Old Dec 7, 2006 | 06:35 AM
5th Gear
arrrggg
I hav no idea, I am wondering if it needs to be re-set by the dealer or something.
Old Dec 7, 2006 | 06:54 AM
Rpappi's Avatar
DRINKING HAS A ME PROBLEM
you should be able to do it. use the search function and see if you can get it by following the instructions.
Old Dec 24, 2006 | 09:59 PM
01tl4tl's Avatar
Another user had a similar problem after unplugging battery. After resetting the radio code, everything else worked again!
Old Dec 26, 2006 | 03:03 AM
Rpappi's Avatar
did you change the car batt or the remote battery
Old Dec 26, 2006 | 07:51 AM
5th Gear
no
I changed the battery in the key fob
Old Dec 27, 2006 | 09:34 PM
01tl4tl's Avatar
Not to overlook the obvious- but is the remote battery installed correctly in place- they can be slipped in upside down which is reverse polarity
Old Dec 27, 2006 | 10:00 PM
TLsMD's Avatar
WINNING
worst comes to worst just order a new one/used on ebay, cheapest way to go....
Old Dec 28, 2006 | 07:28 AM
5th Gear
I can get the red light to blink on the key fob, and the car won't respond.
Old Dec 28, 2006 | 09:32 AM
nyctl's Avatar
did you try to reprogram the remote?
it takes less than 20 secs to do.
Old Dec 29, 2006 | 07:42 AM
5th Gear
I don't know if I did it right, how do you re-program?
Thanks!
Old Dec 29, 2006 | 08:50 AM
nyctl's Avatar
Thanks!
PROGRAMMING THE REMOTE TRANSMITTER (KEYFOB)
Storing transmitter codes.
The codes of up to three transmitters can be stored into the keyless receiver unit memory. (If a fourth code is stored, the code which was first input will be erased.)
NOTE: It is important to maintain the time limits between the steps. Make sure the doors, the hood and the trunk lid are closed.
1. Turn the ignition switch ON (II)
2. Within 1 to 4 seconds, press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the driver’s side of the dashboard.
3. Within 1 to 4 seconds, turn the ignition switch OFF.
4. Within 1 to 4 seconds, turn the ignition switch ON (II).
5. Within 1 to 4 seconds, press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the driver’s side of the dashboard.
6. Within 1 to 4 seconds, turn the ignition switch OFF.
7. Within 1 to 4 seconds, turn the ignition switch ON (II).
8. Within 1 to 4 seconds, press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the driver’s side of the dashboard.
9. Within 1 to 4 seconds, turn the ignition switch OFF.
10. Within 1 to 4 seconds, turn the ignition switch ON (II).
11. Within 1 to 4 seconds, press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the driver’s side of the dashboard.
12. Confirm you can hear the sound of the door lock actuators within 1 to 4 seconds, then push the transmitter lock or unlock button again, or the code will not be stored.
13. Within 10 seconds, aim the transmitter (up to two additional ones) whose codes you want to store in the keyless receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
14. Turn the ignition switch OFF, and remove the key.
15. Confirm proper operation with the transmitters.
NOTE: Once the programming mode is entered, the remote button must be pressed a second time. If the button is not pressed, or if the ignition switch is turned OFF, the programming for all remotes will be cancelled.
Old Apr 16, 2007 | 10:41 PM
bms270's Avatar
7th Gear
Unhappy
didnt work for me
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
acurajj
Sep 19, 2015 03:47 PM
jordanboi
Sep 5, 2015 01:33 AM
