Rev-limiter issue
Old Apr 16, 2007 | 12:37 PM
scwchapman's Avatar
9th Gear
Rev-limiter issue
I have a 1999 3.2 TL and I think something is wrong with my limiter. When I first start the car, the rev limiter doesn't kick in until around 6500-6700. However, after about 3-5 minutes of driving the rev limiter kicks in at 5000-5500, but the power dies at 4500.
Someone PLEASE help me. I have no idea whats going on but I dont like being robbed of revs.
Old Apr 16, 2007 | 02:48 PM
MurkyRiversTL's Avatar
COTM Coordinator
hmmmmmm...... could in be in safe mode..... pm fsttyms1 he had to deal with something like that when he changed his engine.
Old Apr 16, 2007 | 03:41 PM
fsttyms1's Avatar
Is there any CEL light at all?
Old Apr 16, 2007 | 06:12 PM
scwchapman's Avatar
9th Gear
what are CEL lights? I dont know but I can check for you. Safe mode sounds like a culprit, I'll pm him.
Thanks for your help so far, hope to hear more
Old Apr 16, 2007 | 07:23 PM
lockeed's Avatar
Check my thread, I think we may have the same problem my friend...
https://acurazine.com/forums/ramblings-12/pro-e-design-program-anyone-use-157154/
fsttyms1's Avatar
CEL= Check Engine Light.
Also do you/are you able to get vtec to engage at all
Old Apr 16, 2007 | 07:54 PM
lockeed's Avatar
For me, Vtec engage at 5000rpm like usual, but rev limiter kicked in at 5500rpm...
Took it again today, nothing... works perfect... so definitely not a big mechanical problem... more like a secure mode, or preventive.... etc... No CEL
3.2TL Type-S 2002
Old Apr 17, 2007 | 09:01 AM
scwchapman's Avatar
9th Gear
3.2TL Type-S 2002
yea we definitely have the same problem I think. my v-tec starts to engage around 4500 or so, but the limiter stops it at like 5500 MAX. It loses all power even before that, and it happens ALL the time. It's not a one time thing, and NO CEL
Old Apr 17, 2007 | 09:02 AM
scwchapman's Avatar
9th Gear
and is there any way to get it out of safe mode?
Old Apr 17, 2007 | 09:07 AM
fsttyms1's Avatar
We have no idea if you have the same problem.
2nd your 99 vtec should engage around 3900.
The only way to get rid of the problem is to find out what is causing it.
Old Apr 17, 2007 | 09:12 AM
fsttyms1's Avatar
You may want to try to have a code read. There may be one being stored.
How does it shift, How does the motor run? smooth? Have you checked the air filter to make sure nothing is clogging it and installed properly? Have you looked under the hood to see if there are any loose hoses or wires that may not be attached?
snorf
Nov 4, 2019 06:44 AM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
Frathora
Sep 28, 2015 11:29 PM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
carz0159
Sep 20, 2015 06:11 PM
