Key programming
Old Apr 1, 2006 | 03:03 PM
cyrock's Avatar
Key programming
Hi,
Last summer i bought an accord 98 with acura 3.2 tl type s engine in it.
Everything was working fine.
I put my car in a garage for the all winter and when i wanted to start it, in the dash, the green key is flashing !!!!
I think that means the key is not program normally !!!
Wat kind i do to reprogram this key myself.
Thank you,
Old Apr 1, 2006 | 06:44 PM
honda_inspire99's Avatar
Skeet Skeet Skeet
Originally Posted by cyrock
Hi,
Thank you,
Does the key starts the car? The green key should flash whenever u put the key in the ignition and when u turn the car off so thats normal.
Old Apr 1, 2006 | 06:48 PM
Ron A's Avatar
Administrator
I deleted the thread you posted in 3G TL. I figured you reposted here when you learned the Type S engine was from a 2G TL.
And welcome to the forums.
I'm not sure of the 2G TL's, but if they use the immobilizer chip like the 3G TL, which can cause the green key light to flash, then it has to be programmed at the dealer.
Have you checked the battery? If everything else is working, you can turn the key and the engine will crank but it won't start, which means it is the immobilizer causing the problem.. If it doesn't crank at all it might be something else.
Old Apr 2, 2006 | 12:40 PM
cyrock's Avatar
Hi , thx for deleting my previous post !!!!
We tried to boost the car, cause the battery was dead but nothing...they green key was flashing still ...i ll call a dealer on monday and ask him if i can bring my computer and my key then they ll proabbly able to reprogram it ....i ll let you know ...
Pray for me ...
Old Apr 2, 2006 | 09:49 PM
Skeet Skeet Skeet
Pray for me ...
i was going to tell u to do that but u didn't say whether or not the key started the car but keep us posted
Old Apr 3, 2006 | 08:52 PM
cyrock's Avatar
i call the dealer so i have to bring my car there and they will check !!!!
do you know where could i chekc if my engine sertial number are good ....
Old Apr 17, 2006 | 04:12 PM
cyrock's Avatar
so then .. i went it took 3 minutes to get it fix so i m back on the road ladies !!! eheh
i had to bring the whole car u know ...
soupi
14
Nov 15, 2015 11:15 AM
eastcoastguy
Oct 29, 2015 03:00 PM
joflewbyu2
Oct 8, 2015 11:16 AM
malvothegreat
Sep 29, 2015 12:38 AM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
