Key can be removed while still in Drive
'99 TL 123K Miles
I have had this issue for a while and have been lucky the car has not rolled away from me or the wife. I just replaced the ignition switch and this fixed the problem for about a month as well as the problem of randomly shutting off. I can now once again remove the key from ignition without placing the car in Park. Car no longer shuts off randomly so that problem is still fixed but I need get this safety issue resolved. It is an accident waiting to happen.
Apologies if there is a thread on this but I did search and may have not come up with an effective search string.
Thanks!
Thanks!
There was a recall item for the shift interlock on the 1999 TL.
Check with Acura to see if the part in your TL was replaced under the recall. If not, they will install a new one for free.
You can call Acura with your VIN number or you can register your car online at Acura's OwnerLink site.
'99 TL 123K Miles
Thanks!
Thanks!
Always use the parking brake, auto or manual, hills or flat terrain.
I believe the key is retained in the cylinder by means of a solenoid, perhaps it has failed (or blown fuse). Perhaps a call to the dealer who replaced the switch can help solve your problem.
Miner
I live in
i have something just about the same problem except the car isnt started. most of you who turn the key enough to shift the gear so u can take apart the radio know that you can not remove the key while its still in gear correct? well mine can be removed. anyone had this problem also? sorry to jack the thread but it was almost the same problem.
ahsm
09-09-2015 08:35 AM
