keeping engine healthy??
Old Apr 16, 2012 | 04:13 PM
3.2_Vtec's Avatar
i have a TL with 184k. i know doing regular maintance helps, but i wanna know what else does? Im a guy with a haevy foot and will race any honda i see on the road. but i dont want my motor blow up on me or damage it Lol.
so far i changed out the coils/plugs all 6. oil change and what else? coolant flush, engine flush? gaskets and what more? thanksss you!
Old Apr 16, 2012 | 05:47 PM
victus1's Avatar
If you are hammering the pedal, be sure you have changed all the 5 parts for the t-belt service: timing belt, water pump, idler pulley, tensioner pulley, tensioner. Also, the serpentine + power steering belts, and the serpentine belt tensioner should be changed by that mileage.
Old Apr 16, 2012 | 05:57 PM
^that.
along with regular fluid changes, and you're golden
Old Apr 16, 2012 | 09:48 PM
01tl4tl's Avatar
seafoam the engine vac, gas tank, and oil
adjust engine valves--very important!
clean egr system while intake maifold removed for valves
clean iacv inside throttle body
clean throttle air plate, lube cables and return springs
Put the car on ramps or jackstands and ck every nut and bolt you can reach
take brakes apart- clean and lube sliders and pins
flush entire brake fluid now, and once an year- for those who use them hard
special TL bleed order LF RF RR LR
Old Apr 19, 2012 | 06:49 PM
3.2_Vtec's Avatar
Great thanks!
Old Apr 20, 2012 | 10:09 PM
totaledTL's Avatar
Uh, maybe take racing to the track so you don't crash into any of the rest of us trying to share the roads? Merely a suggestion....
Old Apr 20, 2012 | 10:57 PM
soria's Avatar
If you're driving like that, worry about maintaining your transmission. The engine doesn't mind.
Old Apr 21, 2012 | 12:27 PM
01tl4tl's Avatar
I suggest everyone attend track days/high performance school days at your local roadrace track--ck internet for SCCA or NASA racing as guide to track locations, and their schedule will show renters/events
Car clubs and actual schools rent the track for a day, pro race drivers serve as your in car or leading/following car- personal coach--
you driving the TL on a race track!
You learn more than you can imagine and it will change how you drive on the street.
at 200-300$ average for a day, its cheaper than most tickets
and the only cops around--may be instructors!!
Old Apr 21, 2012 | 12:32 PM
01tl4tl's Avatar
our megamoderator fsttyms1 (fast times WON) regularly takes his 00TL w/cl-s engine/6speed,, and over 400kmiles on the car!!!
--to `road america` racetrack for some serious full throttle = max car speed on the backstraight- fun
uzzmaan
Aug 4, 2025 08:29 AM
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
