just made my tl 6speed but its in limp mode need some help
ok i jusy=t installed the cl type s tranny into my 2000 acura tl everything works fine but the car will not rev over 3000 rpms. i wanted to kno can i take a different route as far as ecu wise some say i needed a kpro ecu? are thr any short cuts?
welcome
please see the 6 speed install diy here https://acurazine.com/forums/2g-tl-1999-2003-98/6-speed-conversion-591872/
and ck our master diy list for more info
https://acurazine.com/forums/2g-tl-1999-2003-98/new-official-2nd-gen-tl-diy-thread-706083/
iirc there is a unit available to make it all work easily
you may have something as simple as vtec wire not connected
good luck- Im sure our swap gurus will be here shortly
01tl4tl (07-05-2011)
Well you are using a auto ECU which is looking for DIFFERENT sensors and stuff. There isnt a way around it unless you change ECU and wiring to the CL-S6 OR buy the Richiev6 module. Google RichieV6 module you will get the info on where to purchase it (this sight wont allow the links for it)
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
STL TL-S
09-23-2015 08:52 PM
