Just did brakes....
Old Aug 22, 2010 | 01:37 AM
bashir212's Avatar
Just did brakes....
I just replaced my front pads and rotors guys, due to warpage. Now before the wheel would shake when I brake but now...........when I go highway speeds my wheel shakes a bit and my alignment is good I completed it two months ago??????????
I love the car but this is unenjoyable
Old Aug 22, 2010 | 03:32 AM
F1driver's Avatar
balancing or an alignment issue i think.
Old Aug 22, 2010 | 12:03 PM
gold2003tl (90)'s Avatar
2003 TL-p
check the cv joints
Old Aug 22, 2010 | 12:42 PM
01tl4tl's Avatar
flush the brake fluid,,old fluid is weak, contaminated with moisture and rust,, and causes many problems
flush/bleed order is= driver front then clockwise around the car= LF RF RR LR
blame abs plumbing for the weird order
DOT4 spec fluid, synthetic or regular doesnt matter to street drivers
get 2 qts--use 1.5qts to do the job 110%
for shake prob get wheels balanced- find shop with Hunter Road Force machine- its trick~
Old Aug 22, 2010 | 12:44 PM
01tl4tl's Avatar
how is it under braking?
there is a break in time as pads and rotors match together so slight brake shake can be that
Old Aug 25, 2010 | 03:07 AM
bashir212's Avatar
im going to get my wheels balanced tomorrow , and i sometimes get that slow slip in the braking, but I had done an alignment not to long ago.
Old Aug 25, 2010 | 06:40 AM
01tl4tl's Avatar
you can knock alignment out in 1 good pothole hit
Old Sep 1, 2010 | 02:52 AM
bashir212's Avatar
Hey guys do you think that my left rear wheel sensor being not active could cause this because i have no abs and vsa
Old Sep 1, 2010 | 09:44 AM
01tl4tl's Avatar
uh huh--no sensor = no system function
Old Sep 1, 2010 | 09:49 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Get the tires rebalanced, and then go from there.
Old Sep 1, 2010 | 11:27 AM
01tl4tl's Avatar
as I said before Hunter Road Force tire balance machine
call a few shops- one will have it- they are awesome at finding rim problems-
you can balance a wheel on a low speed spin machine and it looks ok- but at 60 its going to shake
It can find belt problems in tire- thats a possible with yours
will even tell you where to locate a tire on the car if doing all 4- best position for the way that tire tracks- stop rotating tires- not good for them!
ck internet for machine details, but its the only way to go on diagnosing tire shake issues
a good alignment shop will have one
Old Sep 1, 2010 | 02:09 PM
totaledTL's Avatar
Originally Posted by 01tl4tl
....- stop rotating tires- not good for them!.....
You don't think it's wise to rotate tires? Or is this something particular to this issue that I missed?
Old Sep 9, 2010 | 12:41 AM
bashir212's Avatar
I went to the shop with hunter force balancing machine and they told me my problem is not from the tires but front end. Also it was raining again today and when I braked in low speeds there came the vibration.
Old Sep 9, 2010 | 12:57 AM
Mr_skillet's Avatar
make sure you bed in the pads after installation, your vibration could be due to uneven distribution of pad material on the surface of the rotors. Stoptech's page has a good explanation of why you need to do this. As for bed in procedure, search the web for ones specific to your pad, if not, follow generic ones from hawks website
Old Sep 9, 2010 | 04:01 AM
01tl4tl's Avatar
ok were they more specific like: you need lower ball joints?
that would allow wheel movement and shake
if you have performance brake parts- mrheeltoe has an excellent bedding method based on combination of several makers, a bit more detailed than hawks, with an explanation of why you do it http://heeltoeauto.com/httech/YaBB.pl?num=1184261899
non performance and brembos need special gentle care during first 500 miles, before aggressive bedding can be done
Old Sep 9, 2010 | 01:17 PM
rcb2000's Avatar
if it doesn't vibrate until you apply the brakes repalce the rear rotors or have them turned.
Only tires that don't need rotated are non-existant, so rotate the tires regularly.
if the tires are balanced then the issue is a bad CV, worn tie rods or a bad ball joint all which will increase in intensity the higher the speed, If you do not have a vibration until you apply the brakes then you have warped rotors on the car.
Old Sep 19, 2010 | 07:53 PM
bashir212's Avatar
Okay guys just did the balance and still the problem persists, I have new front rotors and pads and I changed the rear rotors only. It seems to get worse now and braking is tougher
Old Sep 19, 2010 | 08:30 PM
01tl4tl's Avatar
a good shop told you there were front end problems,,so you balanced the tires instead,,,ok
BUT
What parts still need replacement in the steering to keep the wheels from shifting and causing vibrations??
Old Sep 24, 2010 | 01:35 AM
bashir212's Avatar
They just did my balancing they did not check my front end.
Old Sep 24, 2010 | 11:35 AM
01tl4tl's Avatar
`I went to the shop with hunter force balancing machine and they told me my problem is not from the tires but front end.`
that shop told you there was more than balance prob--so who has diagnosed it and replaced the needed front end parts?
Old Sep 27, 2010 | 02:51 AM
bashir212's Avatar
They just balanced and they didnt really look at the car.
I just came from a 2 week vacation and I notice that i always have to move my steering to the left and if I hit a crack in the pavement my car/steering goes right.
Could this be wheel alignment???????
Old Sep 27, 2010 | 03:36 AM
01tl4tl's Avatar
yes...
but not from bad alignment--from tie rod ends or control arm bushings failed
That would allow the car to wander constantly as the alignent changes with every bump in the road
get it diagnosed fully by the alignment shop and replace whats needed
If upper control arm bushings bad, replace entire control arm--the lower bushing wont be far behind~
Old Oct 6, 2010 | 11:10 PM
junteschan's Avatar
If your rack & pinion bracket is tight; your inner tierod ends are tight; your upper & lower control arm rubber bushing is tight; upper & lower ball joints are tight; upper & lower strut bushing & bolts are tight, then I would say yes, you have a wheel alignment issue that makes it pull to the right.....
maybe a camber or caster angle issue. Have a wheel alignment check done with a printout. I know Just Tires or Goodyear company owned stores offer a free wheel alignment check with a printout a few years back.
From there ask what their recommendations are then just decline/postpone the repair BUT keep the copy of the printout and have them explain it to you.
Let us know what happened.
TL-GIXXER
3G TL Photograph Gallery
May 20, 2015 06:14 PM
sebas809
Dec 14, 2009 01:22 PM
arrior
48
May 25, 2008 02:26 PM
mzahidi
34
Jan 18, 2008 08:07 AM
lilvanmuzz
1G TL (1996-1998)
20
Oct 31, 2007 07:42 PM
