issue with navigation
Old Sep 3, 2006 | 07:34 PM
akohal's Avatar
does anyone know the "code" that you have to put into the navigation to get it to work? somehow the thing managed to reset itself and now the start-up screen prompts for a four-digit code. i have a 20002 tl-s, if that makes a diff.
Old Sep 3, 2006 | 07:52 PM
Rpappi's Avatar
DRINKING HAS A ME PROBLEM
the code is different for every system. check in your ACURA book. see if there is a card with it on it. or check in your manual.
Old Sep 3, 2006 | 10:37 PM
Bob_F's Avatar
Your local Acura dealer should also be able to get you the code if the navigation unit is the original one.
Bob
Old Sep 5, 2006 | 02:35 PM
tlzib's Avatar
I had the same the problem if you call acura you have to have the serial # from the unit in the trunk to get the code. Just remove all the wires and unscrew the unit from the bracket call acura give the serial # and they can look it up and give you the code. When you get it write it down and put it in a safe place so you dont have to go threw all that bs again.
Old Sep 5, 2006 | 03:10 PM
Bob_F's Avatar
Good advice.
And if you've registered your car online with Acura you can also enter your radio and navigation codes with your car information.
Bob
Old Sep 6, 2006 | 01:42 AM
akohal's Avatar
thanks for the help guys. i will call acura tomorrow with the serial number.
Ol'Dave
Sep 5, 2020 02:56 PM
ShyGuyMcFly83
ILX
Sep 11, 2015 10:51 PM
EE4Life
Sep 11, 2015 10:04 PM
Gianni Formica
Sep 7, 2015 08:28 PM
travr6
Sep 6, 2015 02:11 PM
