Intake noise question
Old Jan 30, 2006 | 05:53 PM
rob0511's Avatar
Exclamation Intake noise question
hi i have an 2003 TL type s and i put a short ram intake on and it make this loud humming noise i have no clue why it is doing that but i def. need help because it is loud thanks, help me please!!!!!!
Old Jan 30, 2006 | 05:57 PM
demolition_x's Avatar
Agean Blue Bishes
its prob the filter. i know the stock box with out the resonator hums. im sure its jsut because the piping is soo short and the filter is foam probably?
its probably just the intake if the noise just happened as soon as you installed it
Old Jan 30, 2006 | 07:04 PM
rob0511's Avatar
so if i put a cold air intake in then it will stop the noise?
Old Jan 30, 2006 | 08:42 PM
Agean Blue Bishes
it could. i had no resonator and it hummed. then i got injen and no more hum. more like a wisp sound cause the filter. goes away after it warms up though.
Old Jan 30, 2006 | 09:00 PM
Pure Adrenaline's Avatar
Dragging knees in
It's pretty much the same with the CAI. My AEM hums intermittently while warming up.
It's the nature of straight-pipe intake systems. If you can't live with the noise, then you need to go back to stock.
Old Jan 31, 2006 | 07:27 AM
rob0511's Avatar
ok so ill try to put in the CAI and i guess we will see, i am new to this car i had an 2002 rsx type s and i traded it in, but what else should i do to my tl?
Old Feb 28, 2006 | 11:24 PM
FaTaPPLes's Avatar
check your pollen filter as well.....my car had a LOUDDDDD annoying humming noise which was a real pan in the neck.....no mechanic could figure out the problem i took it to acura and they charged me 166 dollars for the part....34 for the part 120 for LABOR .... good luck
Old Mar 1, 2006 | 11:30 AM
srgilbert's Avatar
Intake humming
I have an 02 TL-S with the very same problem. I had it in at Acura and they discovered that the noise is because the air filter box (intake) is not sealing properyly. I seems as though some of the hold down tabs were broken by the previous owner and am told that once this is sealed properly the noise will go away. Hope this helps. I'm trying to locate a used air box.
Old Mar 1, 2006 | 11:40 AM
ProvidenceLeaf's Avatar
Back in a Type S
I just went through this problem. Most SRI will make the humming noise that you are describing. Mine did and it was super annoying. I took the SRI off and installed an INJEN CAI. The only humming is maybe during the first couple of minutes when the engine is warming up (and even that is minimal compared to the SRI). Other than that...no hum at all!
here is my thread on this...hopefully this helps you.
https://acurazine.com/forums/showthread.php?t=130960
Feb 25, 2020 09:57 AM
hues10
1G RDX (2007-2012)
Sep 7, 2016 03:47 PM
datadr
Sep 12, 2015 09:12 PM
MyGuti
Sep 12, 2015 06:52 PM
Steven Vitek
ILX
Sep 10, 2015 07:29 AM
