immobilizer replacement
Old Oct 10, 2013 | 05:25 PM
No1isnormal's Avatar
5th Gear
I have come to find that my immobilizer receiver needs replacement. I diagnosed the issue using the factory service manual. When I called to price the part I was told that the dealer would have to reprogram the unit after install. Can anyone confirm this, as the service manual does not. I do not want to pay extra money for no good reason. Also can someone recommend a cheaper source for the part (Immobilizer Receiver)? Thanks in advance!
Old Oct 10, 2013 | 05:38 PM
Skirmich's Avatar
To program a new receiver is easy and free!! Search on YouTube: HONDA FOB PROGRAMMING..
Old Oct 10, 2013 | 08:02 PM
fsttyms1's Avatar
Thats for the remote, NOT the key.
Old Oct 10, 2013 | 08:03 PM
fsttyms1's Avatar
For where to get the part
http://www.acuraautomotiveparts.org/...catdisplay.jsp
Now are you talking about the part by the ignition switch?
Old Oct 10, 2013 | 08:09 PM
5th Gear
Yes. It is the Immobilizer Receiver located around the ignition key cylinder. Has two plugs going into it a 5pin and a 7pin.
Old Oct 10, 2013 | 10:06 PM
Skirmich's Avatar
Awww I miss read then..
Old Oct 11, 2013 | 06:56 AM
fsttyms1's Avatar
You dont need to have the key reprogrammed for that. That is only necessary if you have to replace the ECU where the Immobilizer is actually located and what the key gets programmed to.
Old Oct 22, 2013 | 06:30 PM
5th Gear
Problem solved
After replacing the $125 immobilizer receiver my car runs great. Thank you all. No reprogram no hassles.
Old Oct 23, 2013 | 02:44 PM
fsttyms1's Avatar
csmeance
Jan 7, 2026 06:25 PM
cycdaniel
Dec 17, 2019 10:58 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
niray9
Dec 8, 2015 07:34 PM
whitesoxsfan12
Sep 13, 2015 02:09 PM
