I Have No Heat!!
Old Nov 10, 2007 | 02:36 PM
Toon_703's Avatar
2000 Acura 3.2 TL (185K+)
I Have No Heat!!
Well as u all know its WINTER out, and my car has no heat. Not even any engine heat come out when i turn it to "hot." Basically its bone cold when it is on the "hottest temp" i kno this problem could be the thermostat, and umm the heater core i believe. im not sure. but could someone shed some light on me. PLEASE! im trying to get some ideas and info before deciding to take it to acura or just a regular shop. thanks for yah help guys
Old Nov 11, 2007 | 10:38 PM
Rsoetidjo's Avatar
Rich
If you don't see any coolant leaks from it, the heater core is find. Don't need to replace it.
Usually if you don't have any heat, is causing by the vacum door which control (inside the dash) from cold to hot.
The best bet just take the car to a mechanic.
Cuz they might have to take the dash apart.
Good luck...
Old Nov 11, 2007 | 10:54 PM
derrick's Avatar
Could also be a thermostat that is messed up ... go to mechanic to diagnose. Too many variables that climate control uses to regulate car interior temperature.
Old Nov 12, 2007 | 08:56 AM
fsttyms1's Avatar
if your motor (temp gauge) goes to the normal position its either the water control valve, mix motor or heater core plugged. Odds are its the water control valve.
https://acurazine.com/forums/showthread.php?t=169277
Old Dec 19, 2007 | 05:35 PM
Toon_703's Avatar
Update**
well guys ill have to take the car in to Radley ACura for them to take my dash apart to fix my heating prolblem which turns out to be the heater core and replace the climate control unit.
good note(kinda) regualr price thru the dealership is $1200
Side man at acura dealership $600.00 FLAT
gettin a job done at half pricce so u dont freeze your blass off all winter: RPICELESS
Old Dec 20, 2007 | 07:50 AM
Kam
I got this same problem and just passed the 5 yr mark with only 57k miles...Anyone knows if this is still covered under warranty?
Old Dec 20, 2007 | 04:46 PM
2ndgentl's Avatar
2ndgentl
OH MY GOD, do not let anyone take apart the dash just yet. Mine did the same exact thing, coming to find out it was only the little pully up against the firewall. When you turn it on heat theres this little pully that retracts back and forth and all it does is get stuck sometimes. You have to manually move it with your hand to free it up.
Old Dec 21, 2007 | 09:13 AM
Kam
Can you further explain where this pulley is locateed? A pic or description would greatly be appreciated.
Thanks.
Old Dec 23, 2007 | 04:49 PM
2ndgentl's Avatar
2ndgentl
its almost up against the firewall towards the passenger side. It has like a steel wire controling it.
Jul 16, 2017 07:33 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
TL14
Sep 24, 2015 04:37 PM
