How long do I have before my inevitable doom
Old Sep 25, 2014 | 01:30 PM
Barry95's Avatar
Who needs mods
So i went to get my car inspected this afternoon and the guy told me I have a bad tie rod end. And from what he told me 9/10 the car will roll if I'm on the highway.. Which I am every day of the week. So my question is how long do I have before my car takes me for a ride I don't want to take
Old Sep 25, 2014 | 03:06 PM
nats007's Avatar
Here is the DIY to replace them... Unfortunately, the pictures are not working, but it's a solid write up
https://acurazine.com/forums/second-...y-pics-776677/
Old Sep 25, 2014 | 03:27 PM
Barry95's Avatar
Who needs mods
Thanks man, appreciate it
Old Sep 25, 2014 | 05:27 PM
3.2TLc's Avatar
Get that tie rod replaced ASAP, and check the other side as well. With the age and miles on our old TL's, an inspection of the steering and suspension parts is advised. Most alignment shops will check things out on a rack for free and give ya an estimate for any necessary repairs. Better safe, than sorry !!!
Old Sep 26, 2014 | 01:53 AM
TLZINE99's Avatar
Aggressive steering wheel shakes @ high speed you'll know your tie rod will take a dump soon.
Old Sep 26, 2014 | 11:02 AM
01tl4tl's Avatar
also the wheel separating itself from the steering inputs will be a major clue of total failure, followed by car careening across the freeway into a concrete k-wall = total bummer
This is serious stuff, 9 of 10 to fail is the tech saying- I should take it off the road as unsafe- but you have been notified so its on you at this point!!
parts are not much- try napa and our dealer vendors who cut a major deal for us see VENDOR link at top of pages
If tech looked the car over- he would have said if other side or other suspension steering things were needed- as an alignment is required afterwards- its best to do any suspect parts at one time
Old Sep 26, 2014 | 11:06 AM
01tl4tl's Avatar
If he said it only needs an END those are able to be replaced, keeping the arm and other end
compare parts price to complete assembly with all 3 parts, the labor to replace a rust frozen on tie rod end = I would rather have a new unit for safety and peace of mind
and its simple to remove old part- install new - get alignment = done
Old Sep 26, 2014 | 05:29 PM
Barry95's Avatar
Who needs mods
would it explain the car shaking at about 80 mph? its not horrible but its enough to question whats going on... also i have a slightly damaged rim from the previous owner thats now on the side with the bad rod would the car be shaking from that?
Old Sep 26, 2014 | 07:53 PM
3.2TLc's Avatar
Yeah, a bad tie rod and or damaged rim can cause issues for sure.
If ya don't like shakin' at 80 mph......ya may wanna consider some PM or rotate the tires.
Old Sep 26, 2014 | 09:48 PM
Barry95's Avatar
Who needs mods
i'm replacing the tie rod end tomorrow afternoon after my air bag recall at acura.. is there anything I need to keep in mind when working on my tie rod end?
Old Sep 26, 2014 | 10:08 PM
3.2TLc's Avatar
If "DIY", spray some penetrating oil on the threads. Count the number of threads before loosening the tie-rod end's locknut.....that way your alignment will be relatively close.
If the Acura dealership is servicing this, get your own personal prelube ready beforehand.
Old Sep 27, 2014 | 08:08 PM
Barry95's Avatar
Who needs mods
i totally forgot about this but i had firestone complete auto fix that same tie rod a few months ago and its already bad... also to add onto the madness i went to acura to get my airbag recall done and they told me 1 of my sway bar link is broken and 1 is almost broken.. is that a driveway job?
Old Sep 28, 2014 | 08:53 AM
3.2TLc's Avatar
This thread is from the "DIY" sticky:
https://acurazine.com/forums/showthread.php?t=191709
Old Sep 28, 2014 | 10:53 AM
Barry95's Avatar
Who needs mods
a new development in the story.. the outer is fine and the inner is just starting to go so it gives me more time to fix it
Old Sep 28, 2014 | 12:20 PM
3.2TLc's Avatar
Thumbs down sssShakin' going 80.....
Why risk any potential danger to yourself or others while doing 80 down the freeway ?
Old Sep 28, 2014 | 12:38 PM
Barry95's Avatar
Who needs mods
im working on getting everything fixed I was quoted $1,044 so its just a matter of time to get the money to do the repairs
Old Sep 28, 2014 | 01:56 PM
3.2TLc's Avatar
Say what ? !!! ...... $1044 for some front end suspension/steering work is highway robbery. Total BS !!!
Check Rockauto for good prices on parts. Both sides, inner & outer tie rods along with sway bar end links shouldn't be much more than $250 for all parts. If ya can't DIY, find somebody mechanically inclined to help
ya out. IMO, $200 for labor would be a fair ballpark estimate......so for less than $500, you'll be safe again.
Old Sep 28, 2014 | 07:37 PM
TLZINE99's Avatar
Good luck with that...There's a kit on ebay 4 real cheap around $50 if u cant DIY had someone install it for $100 total spent= $150
Old Sep 28, 2014 | 10:46 PM
Barry95's Avatar
Who needs mods
im getting in touch with my old high school which has a lift so atleast ill be able to get my car in the air and do the sway bar links.. my friend works at advance auto parts so im gonna get parts at discount price and hopefully come out with a fixed product.
Old Dec 24, 2021 | 12:02 PM
NYanks78's Avatar
Does anyone know the torque specs for the inner and outer tie rods? Thanks
emailnatec
29
Sep 28, 2018 04:27 PM
spoiler900
Oct 10, 2015 06:48 PM
polish_pat
Sep 30, 2015 12:22 PM
kb1rl
Sep 30, 2015 10:17 AM
