Highbeam indicator
Old May 13, 2008 | 01:20 AM
Mikaveli54's Avatar
2003 Acura TL-S
Highbeam indicator
I notice today that when i put my high-beams on, my indicator light was not on??????but my other indicators work??? any suggestions or common problems?
Old May 13, 2008 | 02:08 AM
01tl4tl's Avatar
your sure the hi beams were really on- you looked at them personally?
could be the indicator bulb in the dash
why do you use the hi beams anyway- they are worthless compared to the HID low beams
Old May 13, 2008 | 03:40 AM
eleventure's Avatar
I think there are individual bulbs on that back portion of the gauge cluster that are responsible for each indicator. Im not sure how difficult it is to get to them because I never took mine apart. I have the same problem but it my maintenance required light.
Old May 13, 2008 | 07:28 AM
fsttyms1's Avatar
If in fact the high beams came on id suspect the bulb for the indicator is bad and needs to be replaced
Old May 13, 2008 | 10:17 AM
01tl4tl's Avatar
I am guessing the DIY section has a thread on installing different color dash lights and will have direction to remove the plastics, or do the dash reach around and find the quick connector for that bulb---one can hope~
And confirm both hi beam bulbs work- it can be a case like the turn signal bulbs, one goes out and the system acts wierd so you notice right away!!
Old May 13, 2008 | 03:44 PM
Edward'TLS's Avatar
6G TLX-S
It is very uncommon for the dash hi-beam indicator bulb to burn out, unless someone turns on the hi-beam headlight and blinds oncoming traffic all the times.
Old May 14, 2008 | 03:34 AM
Mikaveli54's Avatar
2003 Acura TL-S
Thanks~! i was usin my high beams temp. cause my headlamp went out...
Old May 14, 2008 | 03:06 PM
Edward'TLS's Avatar
6G TLX-S
I don't think many drivers enjoy having the high beam, from oncoming traffic, blinding them.
Old May 15, 2008 | 02:21 AM
Mikaveli54's Avatar
2003 Acura TL-S
its not a busy road, plus it was only to get home...
Jul 16, 2017 07:33 AM
SilverJ
4G TL Problems & Fixes
15
Oct 13, 2015 05:14 PM
jubikej
1G RDX Problems & Fixes
Sep 30, 2015 01:13 PM
h22lude
Sep 27, 2015 06:22 PM
