Here we go again. Headlight problem this time
Old Aug 25, 2015 | 09:39 PM
thatguy2's Avatar
Well today I changed the door lock actuator on my drivers side door and all went well except for a few curse words and frustration. I did disconnect my negative battery cable to prevent shorts or anything. So, on with the story. After I completed everything I reconnected the battery and tried the lock and it worked yay. Now because it was dark when I finished I turned on my headlights....sort of. Corner lights work, the both sides low beams and high beams do not work at all. I'm pretty sure that the bulbs are not burned because this is the second time it happened. First time I clicked high beams and everything came on. Low beams and high beams worked so I thought nothing of it. This time that didn't work. It doesn't turn on. Dare I say I hate this car? HELP ME
Old Aug 26, 2015 | 02:48 AM
01acls's Avatar
Probably your combination light switch.
Old Aug 26, 2015 | 04:43 PM
thatguy2's Avatar
Ill take a look at it. Thanks
Old Oct 12, 2015 | 10:23 PM
thatguy2's Avatar
So it was not the light switch. I did get them working though. Only when I slammed the hood. When I started the car they wouldn't turn on then I slammed the hood and started the car after I turned on the switch and they turned on. This leads me to believe it is a loose wire or ground. Do you have a diagram that can tell me locations of grounds and where wires lead? Head lights seem difficult to pull out. I explored that option.
Old Oct 12, 2015 | 10:44 PM
01acls's Avatar
Just follow the black wire from the inverter. Two inverters, two grounds.
Old Oct 12, 2015 | 11:23 PM
01acls's Avatar
The black wires will end up at the fender apron next to/behind the headlamp L/R (fender side).
Old Oct 14, 2015 | 09:33 PM
thatguy2's Avatar
Yeah I followed the harness and found the two grounds. Where will the inverters be?
Old Oct 14, 2015 | 09:58 PM
01acls's Avatar
Below the head lamp.
tman570
Jun 11, 2019 07:56 AM
Phambam12
Sep 6, 2015 06:57 PM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:02 PM
darknite123
Integra
Aug 30, 2015 03:00 PM
