Help,vsa light
Old Jul 24, 2010 | 05:33 PM
KHI33's Avatar
6th Gear
Help,vsa light
i got a 2002 tl-s will air in the power steering cause the vsa light to remain on? car shows no codes scanner
Old Jul 24, 2010 | 07:47 PM
01tl4tl's Avatar
vsa not related to ps pump, you may have a speed sensor prob or something else
What have you done recently on the car?
had codes ckd where?
To remove air from system if you just changed fluid-
put cardboard under front wheels to reduce friction
start engine and in Park- turn wheels slowly back and forth from full lock to lock
any bubbles will surface and self clear
With engine running- try pushing the VSA button the dash- light go out?
Old Jul 24, 2010 | 09:30 PM
KHI33's Avatar
6th Gear
i just changed all 4 rotors and pads and did timing belt,water pump,tensioner,seals and belts. a buddy of mine checked the codes with a parts store type scanner
Old Jul 24, 2010 | 09:57 PM
01tl4tl's Avatar
Possible you dislodged a wheel speed sensor on one or more of the wheels
Very easy to do on a full brake job if not careful and know where they are
Some pull the wire out because its corroded inside already, or the sensor itself gets pulled up slightly in its mounts..take a look at each of them to start
sensor needs to be at the bottem of its mount
did you flush the brake fluid before the brake work, (prevents crud backwash when you compress calipers) or at least flushed it fully after?
congrats on the 105 DIY, not everyone will even consider doing it!
Old Jul 24, 2010 | 09:58 PM
01tl4tl's Avatar
did you try the switch- it may have been pushed accidentally and turned VSA OFF- making the light come on
otherwise, look at the speed sensors
Old Jul 24, 2010 | 10:50 PM
totaledTL's Avatar
If you push the VSA button, I believe the VSA light will only remain on for the current engine cycle. Once engine is shut off then restarted if VSA syst. is normal the light will be off.
Old Jul 25, 2010 | 07:07 AM
KHI33's Avatar
6th Gear
i never touched the vsa switch. i didnt flush the fluid. im gonna disconnect battery and check all 4 sensors.
Old Jul 25, 2010 | 07:52 AM
KHI33's Avatar
6th Gear
no luck,1 thing i noticed is 1 of the front sensors is almost touching the gear on the cv where the other side has more of a gap,both are seated properly,time to let a pro scan it ? lol
Old Jul 25, 2010 | 11:18 AM
01tl4tl's Avatar
doesnt sound like both are seated properly- it should almost touch
Old Jul 25, 2010 | 06:26 PM
YeuEmMaiMai's Avatar
according to the TL serice manaul there shold be no more than a 1mm gap between the sensor and ring. If there is, you will prolly get a code indicating that the sensor is having issues
the abs codes for sensors are
41 right front
42 left front
43 right rear
44 left rear
Old Aug 16, 2010 | 02:37 PM
BuddyC's Avatar
I'm having an issue with my TCS and VSA lights as well. I worked on my ball joints and had to replace a wheel speed sensor. For some reason my lights are on, so I'm hoping to get it resolved shortly.
I believe the new wheel speed sensor is installed properly, but I'll take another look at it. I'll let you know what I come across.
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
Rob144
Sep 21, 2015 08:18 AM
bryan zaragoza
Sep 8, 2015 12:28 AM
