Help. Running out of ideas.
Old Oct 27, 2025 | 08:28 PM
  #81
Robin_S's Avatar
7th Gear
As well as went through ALL RELAYS AND FUSES. Replaced blue, PGM-FI relay above the drivers side kick panel.
Old Oct 27, 2025 | 09:14 PM
  #82
Jon M's Avatar
WOW! I can see you threw a lot of parts at it. No need to apologize I was just under the impression that you had a 2002.. Anyway it the 2004 has a slightly different fuel system. There are two items I see that could cause the same symptoms.
1. There is a fuel filter in the tank and it is similar to the one in the 2002 but not the same. I will post a picture below. Unfortunately this filter is more expensive than the aftermarket one in the 2002. It will run about $90 +/- a $10. The Acura part number is 17048-SEP-A00. As I have no experience with this OEM part number I can 't say if I would buy one but I would probably go with name brand aftermarket if I could find one and it was cheaper.
2. The second thing I see that is on the 2004 that can cause the same symptoms is a Pressure Regulator Assembly (Acura PN 17052-SEP-A00). This unit is about $105 to $150. This is a unit I have no experience with so I can't tell you if an aftermarket part will work, there are many parts on the Acura that aftermarket parts won't work well. I would say to stay with OEM with this part if you have to replace it.
https://acura.bernardiparts.com/Acur...&assembly=4207
2004 Fuel Tank
Hope this helps!
Jon
Old Oct 27, 2025 | 09:30 PM
  #83
Robin_S's Avatar
7th Gear
Fuel ⛽️
2004 Fuel Tank
Hope this helps!
Jon
Yes sir. I saw that. The fuel pressure regulator is made made onto the bottom of the fuel pump, & the filter is non serviceable, internally. So! With that being said! I have one Beck Arnley 043-3039 otw as we speak!! I will definitely update my progress once it arrives and I get in installed!! Again, THANK YOU SO VERY MUCH!! I Pray this resolves my issues as well!!
Old Dec 29, 2025 | 01:43 PM
  #84
Jon M's Avatar
Did you get it fixed?
Flapjackura
6G TLX Tires, Wheels & Suspension
43
Dec 15, 2020 05:22 PM
asb32952
2G CL Problems & Fixes
Sep 29, 2016 01:18 AM
UNCatTech
Apr 12, 2012 08:36 PM
cbold68
1G TL (1996-1998)
Aug 13, 2011 08:55 AM
Fenix85182
1G CL Problems & Fixes
Jan 24, 2010 12:26 AM
