HELP! One of the belts is acting up again
Old Oct 19, 2009 | 07:36 AM
el.profe's Avatar
Question HELP! One of the belts is acting up again
I did a thread a few months back on alternator belt sound, soem of you suggested I add some belt dressing, I actually went to acura got the entire belt changed. yesterday I wake up and I turn the wheel it makes a sound. This time it wasnt a squeeling sound, more like a gear sound. I opened the hood and everytime i turn the wheel it sound like the wheel was making the sound then affecting the serpentine belt, I checked power steering fluid it doensnt seem like its that. After a while it stops, I guess when the car is warmed up. Any idea?
BTW I changed the serpentine belt like 4 months ago
Old Oct 19, 2009 | 08:07 AM
juanclopez2786's Avatar
did you change both belts? maybe the power steering belt needs to be tightened.
Old Oct 19, 2009 | 08:27 AM
el.profe's Avatar
no only the serpentine belt...so u think the power steering belt might be the issue?
Old Oct 19, 2009 | 10:34 AM
el.profe's Avatar
bump
Old Oct 19, 2009 | 11:54 AM
Steen27's Avatar
Sounds like the power steering belt... (or the tensioner on it)
But - I'm no expert when it comes to our cars... but on an old Chevy... it could be the power steering fluid (low), belt is bad, or bad ps pump. Most of the time it would be the belt going bad and/or needed to be tightened (cause it's going bad and stretching out before it breaks - thus making noise when stressed - as in when wheels are turned)...
Hope this helps.
Old Oct 19, 2009 | 02:06 PM
hANDYcaptd's Avatar
It's the Halladay season!
^ PS belt doesn't have a tensioner. It's tensioned by a long bolt that raises/lowers the PS pump. I'd check the tension on that.
If I remember right, it's about an inch of travel if you push on the side of the belt with moderate force.
Old Oct 19, 2009 | 03:07 PM
fsttyms1's Avatar
Your issue is the power steering belt if your having issues with it while turning the wheel.
Old Oct 19, 2009 | 08:25 PM
el.profe's Avatar
I went to a local spot they said to give it a week cause it only happens the 1st 15 min in the morning.. He said that their is air in the belt... I don't know wat that means.. But imma give it a few being that it only happens when car is cold.. I'll keep u guys posted
Old Oct 20, 2009 | 12:20 AM
draztic1011's Avatar
I been having the same problem these last few mornings. Its from the cold start in the morning. My mechanic said its probably the power steering pump.
Old Oct 20, 2009 | 06:52 AM
totaledTL's Avatar
Sounds like a failing pump. Will the wheels turn smoothly when you turn the steering wheel or does it feel different? You said you checked the fluid it doesn't seem like it's that- what do you mean 'seem'-? Is the fluid level correct?
Old Oct 20, 2009 | 07:56 AM
el.profe's Avatar
its not the fluid.. the fluid is full. when i turn the car on in the mornings, i let the car warm up for alittle until the needle moves up pass the first line. I pull out and everytime i turn the wheel i can hear a sounds. I really dont know how to describe the sounds, i can hear like the belt moving when i turn the wheel, it also sounds like the gears are tight, not sure.. But after a few minutes; lets say 10 minutes of driving the sounds goes away completely till next morning. So I'm assuming it has to do with the belt being cold and not enough oils going through it..
Old Oct 20, 2009 | 09:25 AM
Bxscig's Avatar
The same thing is happening to me and it started happening after the timing belt/water pump issue. The mechanic said he thinks its the pump though.
Old Oct 20, 2009 | 09:30 PM
totaledTL's Avatar
I had a PS pump fail after a timing belt job (different car) too. I'm thinking it's because when the belt for the PS pump was replaced it was tensioned tighter and stressed the (marginal) pump. Just a theory.
Old Oct 22, 2009 | 07:54 AM
el.profe's Avatar
So I was getting ready to take my car to Acura today so they can give me a diagnostic. I had a camcorder ready so I can record the sound,being that the sound dies 15 minutes after the car is on. I turn the car on this morning and no sound is coming from the belts. I did'nt know if to be upset or happy. Today was a warm morning, so Im starting to think the weather has something to do with it. Tomorrow is supposed to be colder, lets see what happens
Old Oct 24, 2009 | 04:49 PM
Found this while searching:
https://acurazine.com/forums/3g-tl-2004-2008-93/p-s-whine-cold-start-up-tsb-fyi-699272/
Old Oct 24, 2009 | 07:13 PM
el.profe's Avatar
your the man..I can stop worrying about it being a big money job
Old Oct 25, 2009 | 10:16 PM
totaledTL's Avatar
Applied to 2004 - 2007 models- 3rd gen.
Old Oct 26, 2009 | 07:28 AM
el.profe's Avatar
Im buying that part today. Ill keep everyone posted on progress. If any one else gets to it before I do, please post info.
Old Oct 26, 2009 | 10:33 AM
totaledTL's Avatar
You researched it? It applies to 2nd gen. models also?
Old Oct 26, 2009 | 06:18 PM
Old Oct 27, 2009 | 09:39 AM
You put the O ring on the first shoulder on the inlet joint, as pictured above. Put some power steering fluid to lubricate the ring a little. Also don't make the same mistake I made, my old black O ring was stuck inside, make sure you take that out. So far, this seems to have fixed the problem.
Old Oct 27, 2009 | 09:45 AM
el.profe's Avatar
Dont do what i did, thats go to the dealer.. Its not covered under the warranty and i got screwed. They did not call me and ask permission to do the job and i got hit with a $65 bill when i could of done it myself
Old Oct 27, 2009 | 10:07 AM
thats because to diagnose it its between $50-$100. so if u didnt want them to do it you would of still had to pay the 50-100 and then the price of the parts u needed to do it.
Old Oct 27, 2009 | 10:37 AM
el.profe's Avatar
I go to acura of manhattan, the women that always takes care of me, she usually calls me before they do work and never got charged for a diagnostic. Today i went with a diff guy, i knew i should gone back with her..thats my fault..
thats because to diagnose it its between $50-$100. So if u didnt want them to do it you would of still had to pay the 50-100 and then the price of the parts u needed to do it.
Old Oct 27, 2009 | 10:38 AM
el.profe's Avatar
1 more thing the o ring cost me 80 cents
Old Oct 27, 2009 | 10:42 AM
If anyone needs an O ring, I have an extra one. Paypal me a $1.50 and its urs
Old Nov 4, 2009 | 08:06 PM
thisguymo's Avatar
My 07 TL was covered under warranty and they replaced the whole pump including the o-ring.
08KBP_VA
Oct 22, 2019 01:55 PM
Jul 16, 2017 07:33 AM
brboy
Oct 5, 2015 11:34 AM
Jboat
Sep 30, 2015 10:58 AM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
