Help needed with over heating problem
That was my Jeep :(
Hey everyone, I could use your help trouble shooting/diagnosing my over heating problem. While driving the car with the AC on, it started to get pretty hot. I was going up a hill and it was a hot day. I hadn’t any problems with the car getting hot at all before this. I turned the AC off, but the temperature continue to increase I pulled over and anti-freeze boiled out. The 99 TL has 140,000 miles on it; the water pump was replaced at 130,000 miles. I tested the radiator cap at AutoZone and it wasn't holding any pressure. I replaced it and put in some more Honda approved 50/50 anti freeze and thought I had fixed the problem. But this morning on my way to work, the temperature got to about 3/4. Both fans are working; both radiator hoses are hot to the touch... Any help would be great! Thanks!
^^ or a thermostat
That was my Jeep :(
Thanks guys, I will try to purge the system completely (I should have done that in the first place). When I added the anti freeze in, I turned the heater on all the way, hoping that would do the trick.
Would both hoses be hot if it were the thermostat?
I have a similar problem and i've heard it could be a blown head gasket, but i've seen my oil and there are no air bubbles and it's the color it's supposed to be. I guess it's only air in the system as stated above. by the way, i'm not using the thermostat since here the weather is pretty hot.
Check your oil and water/coolant and see if it looks abnormal.
I had this problem back in 07 when I took a 300mi trip away from home, it didn't start until I got to my destination. Turns out my radiator cap was bad, had that fixed along with a coolant flush. Hasn't overheated since
That was my Jeep :(
After purging the system correctly, I haven’t had a problem (in 2 days)… I will update you guys if it gets hot again. Thanks again for all of your help!
cycdaniel
12-17-2019 10:58 AM
