HELP! Hub Bearing Frozen!
Sorry guys, but this is the second time I'm posting this because I need help as soon as possible. Here's the situation:
I followed the instructions for replacing a rear hub assembly to a "T", and got the hub assembly off. (it took some coaxing, but later found out why). After I took it off, I looked at the old hub and saw exposed ball bearings and thought "Well that's not right". So I look at the shaft and see the race (the inside part of a bearing) frozen on to the shaft. (see picture) I tried soaking the thing in WD-40 and liguid wrench overnight. And hammered it a couple times with a flathead screwdriver from behind. (probably did more damage than progress). I also tried every wrench i hav in the shop including a strap wrench. Luckily nothing has scored it yet. Can you guys think of what else I can do? I'm thinking of just keeping it on there and taking off the same part from the new assembly. What do you think?
Tried the pipe wrench, but it slid all over it. It just couldn't get a grip on the smooth surface. The size of the pipe wrench may be the problem so I may need to get a bigger one. I also tried to use a hacksaw to put some flat spots on the race, but that suckers hard (I guess it would have to be) The hacksaw didn't even scratch it. Oh well,.. I ended up putting it all back together and am driving it very gingerly until I can take it to the shop. The good news is that I can now disasemble and reasemble that area in good time now.
UPDATE:
I took it into my trusty mechanic (screw the dealer) and had him look at it. He ended up taking a grinder to it and cutting away at it until he could break it off. Took him about an hour and a half (and $160) for the whole thing. So much for saving money by trying to do it myself. At least now I know how to do it if the other side ever goes.
acutee: Unfortunately the gap in behind it is not deep or wide enough to get teeth in there. The puller was my first thought (not that I have one on hand), but after seeing what I had to work with, I knew the puller wouldn't have anything to hold onto.
pdprich: I never tried a dremmel tool. I would have had to go out and buy one. After some serious attempts with a hacksaw, and not even scratching the thing, I guess I thought that it would take some professional brawn to get it off. All I know is that race is pretty damn hard, and takes one heck of a beating without showing it.
Thanks to all of you who tried to help though!
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
