Heater fan whirling noise fix
2000 Acura TL
Been hearing a whirling noise when heat/ac fan is on max speed, so need to remove some debris from the fan motor. This is very easy to do by removing the following as indicated and reinstall
- 3 Bolts
- 1 clip
- tubing
- 3 Bolts
- 1 clip
- tubing
AMart83 (12-23-2014)
Yeah, may also be a good time to inspect the blower motor's wiring harness and replace the A/C cabin filter while in the vicinity. There's "DIY"s on all this common stuff.
I lower mine every time I change my cabin filter to get the crap out with a shop vac.
snorf
11-04-2019 06:44 AM
