headlight replacement
Old Jan 20, 2007 | 12:46 PM
piforeal's Avatar
Question headlight replacement
When changing headlight on tl 03 remove screw on black box . How do u get black box off ?
Old Jan 20, 2007 | 04:45 PM
Blazin_TL's Avatar
Registered User
it twists off
Old Jan 21, 2007 | 11:15 PM
imprezagtr's Avatar
search the forum, there r many threads that teach you how to get it off and get the whole headlight replaced from start to finish.
Luckily for you, i just changed the low beams yesterday, so I still remember the process. After you got the T20 screws off, just twist it according to the arrow indicated on the blackbox.
Old Jan 27, 2007 | 05:59 PM
03c0upe's Avatar
1999 tl
after you take the black cap off theres a black cover thing it says danger etc and it has 2 screw on it...do i take that off to get to the bulb? i guess i better take d/c the battery?
and how would i get to the driver side bulb...theres a lil vent thing in the way?
Old Jan 28, 2007 | 12:25 AM
Split_TL's Avatar
Yes you take the screw off, and twist the black piece and it should come off. You dont have to D/C the Battery but to be safe you can. The dirvers side headlight is the hardest side to get at because everything is in the way. I usually just take off the radiator resavior for more space.
Old Jan 28, 2007 | 04:24 PM
03c0upe's Avatar
1999 tl
i know you twist the black cap off..im askin about after that ...there is a another cap it says danger etc..and theres 2 phillip screws..do i remove those?
Old Jan 28, 2007 | 07:59 PM
Bob_F's Avatar
No, the only screw you need to remove is the T-20 Torx screw that keeps the large protective cap from rotating. (I just replaced the bulbs in my 1999 TL with another set of OEM Philips 4300K D2Rs.)
After you rotate the large cap off, you twist the smaller bulb connector cap off by rotating it counter-clockwise about 45 degrees. At this point you can see the back of the D2R bulb and it's held in place by a spring loaded clip. The clip is released by pushing it down and moving it slightly to one side to get it off a catch. (If you look at it carefully, you'll figure it out.)
Once the spring clip is released you can pull the bulb out and replace it. Be careful not to touch the glass part of the new bulb since the oils fom your skin can cause a premature failure.
Then reverse all the steps to finish the installation.
If you disconnected the battery, be prepared to enter the security code for your radio and, if you have one, the navigation system.
Bob
Old Jan 29, 2007 | 04:16 PM
03c0upe's Avatar
1999 tl
when i took the first rotating cap off..i dont think i saw the smaller bulb connecter..i saw anohter black cap with the hazards on it...
Old Jan 29, 2007 | 06:28 PM
Bob_F's Avatar
Yes, I think we're describing the same thing. It's a small black cap/connector that fits onto the bulb with a twist connection. Once you remove that by rotating it counter-clockwise, you'll see the back of the D2R bulb. Unhook the spring metal cliip holding the bulb in place and you can pull the bulb out and replace it.
Bob
Old Sep 21, 2007 | 09:36 AM
jayunsplanet's Avatar
The search function sucks. I've searched for a FULL and complete how to. It doesn't exist. There are guys that have said just take off the bumper, unscrew something, and you're done. That's missing a few steps and things to watch out for...
Old Sep 21, 2007 | 10:40 AM
01tl4tl's Avatar
I agree- ordered new housings for my 01 and will do a proper DIY pic set for all.
From what I have seen, it really is just remove the bolts for the bumper cover and the plastic plugs that hold it and the inner cover in place, then remove approx 5 mounbting screws for housing with special "torx20" screwdriver from walmart, (GM cars use this same srewdriver)
batt needs to be disconnect for safety and lights should not have been used for several hours- they hold a charge of electricty for a few hours min! caution!
Old Sep 21, 2007 | 01:36 PM
fsttyms1's Avatar
You dont have to remove teh bumper to replace the bulbs!
Old Sep 21, 2007 | 03:53 PM
01tl4tl's Avatar
But I really really want the practice Kris!! Was expecting the new housings yesterday and it seems they have not left LA yet, bassturds
acuraST
Sep 17, 2015 02:31 AM
theinsvnity
Sep 10, 2015 10:22 PM
Phambam12
Sep 6, 2015 06:57 PM
voigt
Sep 2, 2015 10:44 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
