Head lights problem
Old May 20, 2010 | 03:53 AM
elchido80's Avatar
4th Gear
Head lights problem
I have 00 Acura TL and I feel like my head lights are down more then they ment to be. I changed the HID bulbs becase one of them was kind of yellowesh so I changed both bulbs thinking that both bulbs are new brighter it will help me whatch the road better but no is the same as before i changed the light bulbs? Is any body that can help with these issu?.....
Old May 20, 2010 | 07:36 AM
jdjohn84's Avatar
2003 TL-S w/Navi NBP
When you say they are "down", do you mean they aimed down too low? New bulbs wouldn't help with that. Pull up close to a wall or solid fence with your lights on and check the aim. You may need to adjust them.
Old May 20, 2010 | 11:08 AM
01tl4tl's Avatar
an 00 would be ready for bulbs - what brand did you use?- how much were they?
and what kelvin color rating, stock was 4300 many go with a 5000k or 6000k for more blue effect when looking at them
if the shocks are worn and car is sagging slightly you can DIY adjust the light height with a + screwdriver--there is a diy thread on it
very simple- look at top of light housing where it meets the car body- see the Up Down indicators stamped on plastic- now look on back of housing for plastic V channel- slip a + screwdriver down that at angle till it hits the gear for the adjustment-
turn screwdriver so it acts like an upper gear and turns the one below it- moving light!!
Mark the brightest spot on wall with tape for referance starting point and adjust, diy should have specs for light height at what distance from wall
driver side needs to be down lower so you dont blind traffic
pass side goes right and farther to spot pedestrians and edge of road lines
Old May 20, 2010 | 11:51 AM
elchido80's Avatar
4th Gear
<P>Thank's&nbsp;&nbsp;I would do that. I used Philips 6000k and I pay $147.00 for a pair on Ebay.But I&nbsp;have&nbsp;another cuestion any budy knows&nbsp;what's&nbsp;lumines means? Thanks bould of you for help me with my problem...</P>
Old May 20, 2010 | 02:27 PM
01tl4tl's Avatar
phillips are good brand- you will be fine with them
Did you install new ones the same direction-that outside wire, and the metal cover over bulb thats inside the housing- is that in place? or fell into housing
easy to do when installing bulbs--the bulbs are seated flat? and the metal arm to lock them in is sitting good?-that arm is part of the attachment for the inside shield, a screw gopes thru both if i recall
Any of those will make the beam height off- but if they were low before bulbs- then do the adjustment as I suggested in post above
They do need about 50 hours of use to get the color and brightness stabilized
Drive with low beam headlights on all the time to get hours on them
Lumens is the light output-brightness
Kelvin is the color scale compared to natural sunlight and the eyes abilty to differentiate objects- 6500 is noon sun,
Old May 20, 2010 | 06:32 PM
elchido80's Avatar
4th Gear
Yes! I did the same as I pull the oldones out. I make sure that every thing get sited right, nothing was lose. I'm going to do whatyou toldme to do on the first thread. I'm just waiting in to the sun light goes down. Thank's again..
Old May 20, 2010 | 07:59 PM
01tl4tl's Avatar
ck the diy section- probably a thread on exact measurements
That section is divided by groups- lighting- brakes- suspension
so you would look in lighting- exterior
ck your tire pressure before starting- that will throw you off
34 -36 psi all around works for most tires, a bit more for low profile aftermarket tires
Old May 21, 2010 | 12:14 PM
elchido80's Avatar
4th Gear
Thank's I well check and that?
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
RLX-Sport Hybrid
3G RLX (2013+)
43
Dec 16, 2015 10:45 PM
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
Ny1718
Sep 11, 2015 09:21 AM
