have a wierd missfire problem
Old Mar 12, 2010 | 08:57 PM
  #121
Rajca's Avatar
wham bam thank you ma'am
wrong feeler gauge or the cylinder wasnt at TDC when u were doing the adjustment
Old Mar 12, 2010 | 09:24 PM
  #122
thinhthan's Avatar
well i used a craftsmen feeler gauge. i used .22 for intake and .30 for exhaust. and i put the mark on the cam with the mark on the timing cover. i first set it to cylinder 1 than turned it til 4 than 2 than 5 than 3 than 6 and after i was done i put it back to 1 and started the car and thats what it started doing
Old Mar 13, 2010 | 03:16 AM
  #123
thinhthan's Avatar
i guess ima just go buy me a new feeler gauge and redo the job. its was a b!tch adjusting the valves in the rear
Old Mar 13, 2010 | 04:54 AM
  #124
Rajca's Avatar
when u were turning it, u sure u didnt turn it and somehow go past the mark then turned it back a little it so the lines line up? that will give u a wrong reading. was the engine stone cold?
Old Mar 13, 2010 | 10:29 AM
  #125
fsttyms1's Avatar
Also did you make sure that you had the crank mark at 0 and the front cam at #1? If you just had the cam at 1 you may be off by 180 deg.
Old Mar 13, 2010 | 12:12 PM
  #126
Rajca's Avatar
Being off my 180 will cause some serious damage when he starts the car. And I doubt that he would be able to adjust all valves on that cyl if he was off by 180
Old Mar 13, 2010 | 03:43 PM
  #127
thinhthan's Avatar
i did go past the mark but it was prob about this far off |--| it was even a lil less than that
  #128
thinhthan's Avatar
i didnt check the crank i only had the cam at #1
Old Mar 13, 2010 | 03:44 PM
  #129
thinhthan's Avatar
so you think i cause some damage? and i cant find a go no go feeler gauge anywhere. they only got the straght flat ones they dont got any that is bent in the front
Old Mar 13, 2010 | 03:49 PM
  #130
Rajca's Avatar
thats a lot that u went past. u dont need a go no go feeler gauge.i picked the smallest spec and that worked for me. adjusted it till their was some tension on the gauge.
Old Mar 13, 2010 | 04:41 PM
  #131
thinhthan's Avatar
what do you mean thats alot that i went past?
Old Mar 13, 2010 | 04:44 PM
  #132
Rajca's Avatar
yes. it has to be dead on. our engines are very picky
  #133
thinhthan's Avatar
so will i have to redo all the valves again?
Old Mar 13, 2010 | 04:49 PM
  #134
Rajca's Avatar
yup, and hope that u didnt mess anything up
Old Mar 13, 2010 | 04:51 PM
  #135
thinhthan's Avatar
im really hoping it would suck if i did because i didnt save anything from the last motor that was in the car. i knew i should have saved the head of the other motor
Old Mar 13, 2010 | 05:08 PM
  #136
thinhthan's Avatar
to put the crank at tdc i gotta align the middle mark on the crank with the arrow on the cover right?
Old Mar 13, 2010 | 05:10 PM
  #137
Rajca's Avatar
what i do it rotate it till #1 mark on the cam is with the mark on the housing, then see if u can move moth rocker arms up and down slightly with ur hand. that means that both valves are closed and ur at TDC. or do what kris said with the crank
Old Mar 13, 2010 | 05:12 PM
  #138
thinhthan's Avatar
how do i make sure the crank is at 0?
Old Mar 13, 2010 | 05:23 PM
  #139
Rajca's Avatar
the mark. read what kris said
Old Mar 13, 2010 | 06:40 PM
  #140
thinhthan's Avatar
so i broke one of the bolts that holds the valve cover to the head. i broke one of the short ones right underneth the intake manifold. would i be ok or will what can i do?
Old Mar 13, 2010 | 08:37 PM
  #141
thinhthan's Avatar
so i rechecked the valves and everything was good.
Old Mar 13, 2010 | 10:50 PM
  #142
Rajca's Avatar
how does it run?
my tl wont stop misfiring no matter what i do to it today. go wot, still misfires, usually it will be all good once i break the wheels and rpms shoot up. gonna run a compression test tomorrow
Old Mar 14, 2010 | 05:13 PM
  #143
thinhthan's Avatar
it feels like i kinda lost power a lil bit. its still sounds like a knocking sound kinda.. ill try and post a video for you later
Old Mar 14, 2010 | 08:45 PM
  #144
fsttyms1's Avatar
Stop now. Align the crank to TDC, make sure the #1 cam mark is spot on. It cant be off by any bit. If a little bit didnt matter then the little bit you needed for adjusting the valves wouldnt matter. Make sure every thing is aligned, get the feeler gauge out and make sure every one is in spec again. When you adjust each one make sure the line is set perfect before adjusting.
Old Mar 16, 2010 | 09:14 PM
  #145
Rajca's Avatar
been busy last weekend so i didnt touch teh tl. but the fast two days it drove great. until early this morning when i hit something on teh street or a curb. took my eyes off the road for 3sec and then bam. felt like i blew a tires i pull over and blew both pass side tires, shock is garbage, upper control arm is garbage. lower control arm is in teh shape of a banana (should be straight), radius rod is bent, inner fender cover is garbage, fender is bent a bit, axle is garbage. what a bad way to start the morning. was late to work and had to get the tl towed home.
also front rim is scratched up to hell FML
Old Mar 16, 2010 | 09:20 PM
  #146
fsttyms1's Avatar
Daym. You arent having good luck
Old Mar 16, 2010 | 09:24 PM
  #147
Rajca's Avatar
not with the tl that is.
Old Mar 17, 2010 | 06:26 AM
  #148
totaledTL's Avatar
Wth did you hit??
Old Mar 17, 2010 | 07:48 AM
  #149
Rajca's Avatar
Either debris on the road or a curb. But I don't understand how my rear tire blew out if I hit a curb? I was doing 45-50mph (speed limit basically). But it happened. What pissed me off was that the cop that showed up gave me a ticket for improper lane usage. What fuckin bs. I told him nothing happened and I'm getting the car towed home. So he check what I could have hit and doesn't know either so he writes up some bs. Fuck the cops. The screwed me over so many times
Old Mar 17, 2010 | 10:10 AM
  #150
totaledTL's Avatar
Go to court and see if they will drop it. Maybe the cop won't even show up. Nothing to lose right?
Old Mar 18, 2010 | 06:02 PM
  #151
Rajca's Avatar
im just gonna pay for it and get it over with. i dont have to to bs around
found out the sway bar is bent fml
this is the lower control arm, top is new. bottom is old bent one
Old Mar 18, 2010 | 09:14 PM
  #152
juanclopez2786's Avatar
is the lower ball joint busted too? theres alot of grease where it goes on the old arm.
Old Mar 18, 2010 | 09:19 PM
  #153
Rajca's Avatar
its not busted. but i did get two tires and when they tried to balance the front rim it was asking for 15 ounces on the inside of the rim and 18 ounces in teh middle. it was literally an oval shape. anyone have a tl type s rim? condition doesnt matter as long as its round and not cracked
Old Mar 20, 2010 | 01:47 PM
  #154
Rajca's Avatar
after putting everything back together, the tires hits the top of the knuckle. so now i need a new one of those.
Old Mar 20, 2010 | 01:50 PM
  #155
Rajca's Avatar
and also need two new rims instead of 1, im about to total the tl. just fuckin one problem after another.
Old Mar 20, 2010 | 03:01 PM
  #156
fsttyms1's Avatar
ouch
Old Mar 20, 2010 | 03:10 PM
  #157
jxp0184's Avatar
Tl
I have a '03 TL Type S, 73000 miles and I've been having the same frustrating misfire situation that you do. Rough at idle, sluggish exceleration, throwing up misfire codes (unsure which ones). Brought it to Acura who said I needed a valve adjustment. Did that as well as change plugs & clean EGR and a day later it started happening again.
Mechanic told me the next step might be replacing the EGR.
Have you figured out what's causing it yet? I'm afraid I'll end up dumping lots of money into things that aren't going to fix the problem. Can't afford it since I have no knowledge to fix it myself and have to take it to a shop for everything.
Old Mar 20, 2010 | 04:50 PM
  #158
Rajca's Avatar
i also replaced the egr and still had a misfire. its either an injector or ecu/wiring problem that i have narrowed it down to
Old Mar 22, 2010 | 07:03 PM
  #159
Anachostic's Avatar
This is from the service report when I had a similar shaking problem 100k miles ago:
CEL, shakes at 1.5k rpm - misfire code, EGR stuck closed - Valve Set EGR
Random Misfire - Remove plentum, clean carbon from intake - Air Intake BG
Looks like you've been there already.
Old Mar 22, 2010 | 09:32 PM
  #160
Rajca's Avatar
just a bit of an update. knuckle looked good. axle was shot. so replaced teh axle put everything back together. go to start the car. and i got no power. no where. no light, no crank, nothing. car is completely powerless. go to get a jump from another car and still got nothing. thinking its a loose ground somewhere. idk. its one problem after another with this car.FML
