Has to be the bent rims....
Old Aug 10, 2005 | 09:33 AM
Eisenhulk's Avatar
MUCH bigger than you!!
Well, I installed new Brembo rotors (Front) on Sunday night, then new tires (Also on front) and the shake is still there. Anything above 60mph, and I'm getting vibration. On a scale of 1-10, I'd say the shake is a 4. Nothing major, but still annoying. The place that installed my tires said both front wheels were bent, with one being worse than the other.
Opinions? Suggestions?
Old Aug 10, 2005 | 10:18 AM
fsttyms1's Avatar
get new rims. if they are bent they either need to be repaired (usually very expensive) or replaced. that is the only thing that will make the vibration stop
Old Aug 10, 2005 | 11:46 AM
Eisenhulk's Avatar
Thanks again, bro. You've been a HUGE help! I'm currently dealing with some people on getting two NEWer rims. Just sucks....I'm going to have to them mounted...AGAIN.
QUOTE=fsttyms1]get new rims. if they are bent they either need to be repaired (usually very expensive) or replaced. that is the only thing that will make the vibration stop[/QUOTE]
Old Aug 10, 2005 | 01:00 PM
fsttyms1's Avatar
NP. yea having to un mount and remount is a pain, but worth no more vibration
Old Aug 15, 2005 | 09:29 AM
VTEC11's Avatar
Arn't factory RIM's expensive? Unless your getting used, in which case they could also be bent.
Old Aug 15, 2005 | 10:43 PM
jdmsoarer's Avatar
Well, if your rear wheels aren't bent, swap them to the front and front to back. Since you're saying the shaking is minor, you won't feel it as much if they were in the rear. good luck to you!
Old Aug 16, 2005 | 09:03 AM
Eisenhulk's Avatar
Way ahead of you, boss. That's what I plan on doing now. No way my back rims could possibly be bent.
Old Aug 16, 2005 | 06:59 PM
jdmsoarer's Avatar
I'm glad you figured that out on your own then! good luck to ya..
ExcelerateRep
Sponsored Sales & Group Buys
Jan 6, 2016 09:59 AM
ExcelerateRep
Dec 11, 2015 12:58 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
sgmotoring
Nov 12, 2003 09:53 PM
