Has anyone gotten the Home Link to work?
Old Jan 7, 2011 | 02:04 PM
floored4door's Avatar
I have tried to get my home link to work on two different (from what I assume rolling code) garage door openers and I can't get mine to link with either. No response to either of them. This was of course after resetting the homelink in my TL by holding both outer buttons for 20+ seconds. Does anyone have any advice?
Old Jan 7, 2011 | 02:09 PM
nj2pa2nc's Avatar
it's a car-drive it
I found that someone push a button on the garage door opener itself at the same time I pushed the homelink button in the car. Had my husband do the garage door opener since he does not mind climbing ladders. I pushed the remote and homelink buttons.
Old Jan 7, 2011 | 08:42 PM
01tl4tl's Avatar
there is help in the diy section on setting it up
Old Jan 7, 2011 | 10:03 PM
nishant11's Avatar
Homelink website shows you video or step by step instructions on how to program by choosing your vehicle and door opener manufacturer details.
http://www.homelink.com/vehicles.php
Old Jan 8, 2011 | 12:07 AM
bl3ujay07's Avatar
Agreed! My brothers (now also my) garage requires a rolling code. Tried couple of times, and only time we were successful in doing is so as stated above!
Old Jan 8, 2011 | 04:23 PM
Thanks all, I will give it a shot! I suppose I should of searched first...
Old Jan 11, 2011 | 01:38 AM
murky's Avatar
Some openers, like the Genie that was in the house I bought, can be set to operate at more than one frequency. The default frequency was incompatible with homelink, but the other works. There was a button or switch on the opener motor assembly. If you look at your opener it probably has the model number on it. You can probably find an owner's manual using Google if you don't have a hard copy.
Old Jan 11, 2011 | 11:12 AM
Flipster23's Avatar
mine works on both my houses
Old Jan 13, 2011 | 05:26 AM
sabertooth's Avatar
5th Gear
mine used to work on both garage doors then one day tried using it when power was out(didnt know at the time) and now wont open that garage door...lol like everyone said already have someone push the garage door opener while you hold down the home link botton and it should work. gl
Old Jan 13, 2011 | 10:12 AM
rcb2000's Avatar
actually all you have to do is push the button on the opener then do the program for the home link. it's a rolling code so it has to be sync'd first and that is what pushing the button on the opener does, one man operation you don't have to push them both at the same time just have to push the opener then program the car's remote.
Old Jan 13, 2011 | 11:09 AM
nj2pa2nc's Avatar
it's a car-drive it
tried that on our garage door opener-did not work so we had to do the 2 person thing.
Old Jan 13, 2011 | 12:14 PM
rcb2000's Avatar
It must depend on the brand and model of opener then as I had no issues doing it that way.
Old Jan 13, 2011 | 01:53 PM
Tried the two person way yesterday. No such luck, just watched the video and from the looks of it I am doing it wrong. I need to sync the home link with the remote first, then the opener 2nd. I'll let you guys know if I get that to work.
Old Jan 15, 2011 | 10:13 PM
dangeris's Avatar
I use mine and on my wife's MDX all the time. My garage door openers has a button that you have to push and have 30 seconds to get back to the car and press the respective button. It's not just pushing a button in the car that will set the homelink feature
Old Jan 22, 2012 | 06:02 PM
tc5280's Avatar
Flagship Aspec
I've got mine to work on three different garages by holding the garage remote button and the homelink button at the same time. Pretty sure one of them was rolling code
mada51589
Jan 9, 2025 04:40 PM
acurajj
Sep 19, 2015 03:47 PM
jordanboi
Sep 5, 2015 01:33 AM
