H.I.D Problem Need Help!!!!!!!
Old Apr 24, 2006 | 07:46 PM
nb_exit9er's Avatar
NB_Exit9eR
hey guys i got problems with my h.i.d.s .....i got new stock d2r's but i really wanna know how to aim them.....they are pointing down because a 1989 camry light up the road more than my car......the other problem is that my right side headlight is kind of yellowish while the other one is more white looking....i need help on fixing this i've seen other tl's and their headlights look blueish...thanks for the feedback. thanks guy!!
Old Apr 24, 2006 | 11:03 PM
tweedle99's Avatar
There should be some marking on the plastic trim on top of the headlight like this U-D and L-R. You can adjust the light by turning the screw appropriately.
As for your yellowing headlight, the bulb is going bad. The bluer light is achieved by replacing the 6000K bulb for 2nd gen. 3rd gen TL use the same bulb color as we do but due to the refraction of light through the projector, it looks blue off center.
Old Apr 25, 2006 | 08:22 AM
nb_exit9er's Avatar
NB_Exit9eR
i dont think is going bad because my boy lu is having the same problem and his bulbs are brand new also(bulbs are from the dealer and they were real white at the beginning) ......but its kinda funny because that bulb lights up more than the other one......i didn't see any screws! is there a D.I.Y????
Old Apr 25, 2006 | 09:24 AM
fsttyms1's Avatar
First did you replace both at the same time? Also it takes about 100 hrs for them to break in.
Pop your hood and look on the plastic shroud abofe the headlight. You will see a U-D there is a bolt to turn if you look straight down behind it. Also just dont go cranking on them, your lights may be aligned properly. HID's have a Cut Off line. they just dont go blending in like halogens
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
