Groaning noise when steering after backing up
Old Feb 23, 2011 | 10:38 PM
Got a weird problem. After I back out of a parking spot and I turn to pull out I hear a groaning noise and it is difficult to steer. It also "feels" like something is grinding in the steering wheel. Once I get moving though everything feels fine. Can anyone tell me what might be wrong?
This is on a 2000 TL with 123k miles
Much thanks in advance!!
Old Feb 23, 2011 | 10:48 PM
03tLsNBP's Avatar
MechEng
Same things happened to me. I had to change my front lower ball joints.
Old Feb 24, 2011 | 01:39 AM
01tl4tl's Avatar
are you moving while turning the wheel? or stopped then turn it
It needs to see an alignment shop for inspection-diagnosis
could be a few things and none are good to ignore
ps pump??--system flush--hows the fluid look and smell
ever flush ps- thats due every 60kmiles
Old Feb 24, 2011 | 08:27 AM
I am moving very slowly, not exactly dry steering, but enough so I clear out of the parking spot
I guess I'd better get it looked at, although I'm not too keen on spending too much money as we plan on trading it in later this year so that we can get a *gasp* minivan. At least I'll be inheriting a 2005 MDX from the wife
Old Feb 24, 2011 | 11:23 AM
01tl4tl's Avatar
an alignment shop can find the prob for you
Old Feb 24, 2011 | 11:25 AM
01tl4tl's Avatar
some of those new mini vans have a lot of trick parts avail--
so mom can still shuttle the kids,,,
but it has a 1.5 inch sway bar under it~ for your runs to hardware store!
Old Mar 6, 2011 | 09:27 PM
tkerri1's Avatar
Power steering fluid is low.
Old Mar 6, 2011 | 09:39 PM
friesm2000's Avatar
B A N N E D
the 2g and 3g Odysseys don't look too bad, especially if lowered some , with a nice set of wheels on it
and imake sure to tell the wife you want to do this to it, since you will probably be keeping it for at least a couple of years
http://www.youtube.com/watch?v=0vgEZmxNHCY
Old Mar 18, 2011 | 02:22 AM
acuratech1's Avatar
the first thing i would do is check your power steering fluid...if thats ok i would sit with the wheel straight and the car running rev your car up slightly and turn the wheel back and forth if it gets easier your ps pump is on the way out....seen it a lot its a pretty common problem.
Old Mar 18, 2011 | 02:52 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
As suggested, check your PS fluid level.
Old Mar 18, 2011 | 11:00 AM
01tl4tl's Avatar
ever change the ps fluid? due every 60kmiles iirc
correct level is NEAR the Max mark but not at it--need some splash room for fluid in motion
watch with engine running and you will understand
Feb 25, 2020 09:57 AM
PortlandRL
Sep 14, 2015 12:01 PM
Steven Vitek
ILX
Sep 10, 2015 07:29 AM
MyKids&Cars
Sep 2, 2015 12:03 AM
