Hids
Old Mar 8, 2011 | 12:04 AM
g3t0ffma1nuts's Avatar
Hids
Bought new bulbs from hidextra and installed them today. One bulb wasn't lighting up and thought it was the bulb. So I switched the sides and found out it was the bulb. So I put my old ones back in and I still have the same problem. I'm thinking it might be my ballast but it was working perfectly fine before I installed the new bulbs. My left side ballast is working fine it's the right side I'm having problems with. It'll turn on and the bulb will light but will shut off after 5 seconds. Any solutions to my problem?
Old Mar 8, 2011 | 01:09 AM
So I've switched the relays and checked the fuses and still having problems. I'm not thinking it is the ballast. Should I get an oem ballast or aftermarket from hidextra?
Old Mar 8, 2011 | 08:48 AM
dan lazer's Avatar
~~~ SKY'S THE LIMIT ~~~
honestley buddy----i had the same problem with my passenger side---i got new 10k bulbs and installed them----the left passenger side didnt work----all i did was shake the little plug that plugs in the back and it worked fine-----ITS NOT THE BALLEST------ITS THE PLUG-----TRY THAT OUT--------let us know how it goes !!!!!
Old Mar 8, 2011 | 12:31 PM
I'll try that out today thanks.
Old Mar 8, 2011 | 06:00 PM
So I found out the problem. My ballast had water damaged even though there wasn't any moisture in the housing. I took off the power connector to the ballast and found moisture in it. Took off the headlight and the ballast. Opened it up and slot of moisture was in side. I cleaned it up an let it dry. Resealed them and it's working now. Hopefully it holds up.
Old Mar 8, 2011 | 06:42 PM
dan lazer's Avatar
yea hopefully it holds up----so wait----did u bake them open in the oven you mean ????? if soooo you shoulda took that yellow reflector out-----i seen the DIY for that---i did it to mine and they look amazing----such a big difference !!!!!
keep us posted though !!!
Old Mar 8, 2011 | 10:11 PM
I cleared my headlights long ago. Looks better cleared. I changed the amber bulb to chrome and it looks even better in daylight. I wasnplanning to get switchbacks but didn't want the cops on my ass
Old Mar 8, 2011 | 11:37 PM
01tl4tl's Avatar
you were able to take the ballast itself apart?
if its been water soaked, its safer to get aftermarket replacement and not have to worry about fires~
wires and connections get crudded and resistance goes up..not good
Old Mar 18, 2011 | 02:13 AM
acuratech1's Avatar
yea i have to agree....i know its expensive from acura becuase it comes with the ignitor and ballast combo but you cant go wrong with oem....
Old Mar 18, 2011 | 10:52 AM
01tl4tl's Avatar
on some parts I will agree with you- stay OE,,the TL water pump seems a good unit
On many others- I feel the car maker is looking to buy cheap in bulk ie: the cabin blower power connector..oil filters,,,
for what acura wants for the ballast and other parts, compared to the quality of aftermarket suppliers--now that the weaker companies have folded and the good ones remain (see our vendor sponsors for a few ideas)
for my 01 with the alternating off headlight prob,,its going aftermarket full kit
80 bucks is awesome!! (paid more for my kaixen bulbs)
I use the lights mostly in day for safety and rarely drive at night,,but anything has to beat suddenly driving with 1 light and not realizing it doh~~
Old Mar 18, 2011 | 05:57 PM
acuratech1's Avatar
hey i hear you guys that dont wanna spend the money the only reason im buyin the factory ones is becuase my honda district rep is covering half the cost plus my employee discount
Jul 16, 2017 07:33 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
