Gauge Cluster Problem
Old Oct 5, 2018 | 07:29 PM
Kayde Roylance's Avatar
3rd Gear
So today while driving my gauge cluster stopped working. The gas and heat seem to be right, but the rpm and speedo gauges aren't right. The speedo shows nothing it stays at the 0 and never moves and the rpm gauge sits right at 2500 rpm at idle and when driving hits 3000 rpm and stays right there no movement. The rpm gauge at idle sat at 1000 rpm give or take. I would like to know how to fix it ASAP.
Old Oct 9, 2018 | 12:39 PM
Arkady's Avatar
I'd say start off with the simplest and check your fuses. On the '99TL, fuse #6 in the driver's under-dash fusebox handles the gauge cluster.
Old Oct 9, 2018 | 12:59 PM
did you remove your gauge cluster in the past? Could be something like a loose connection in the back. How's the backlight at night?
h22aDc2
4G TL Problems & Fixes
Mar 4, 2014 05:51 PM
motoxrider295
Jul 23, 2008 04:22 PM
motoxrider295
Jul 23, 2008 12:59 AM
Tumby
1G TSX Problems & Fixes
Mar 24, 2008 05:30 PM
UA5-TL
Dec 25, 2002 11:48 PM
